Author Topic: Hurricane Electric BATTERY TIME Part 2  (Read 1351 times)
dastardlydan
« on: March 30, 2007, 12:53:10 AM »
  Just a question on charging a bank of battery.
I now have 10 batterys all 6 volts,
if you count the cells that 30 cell.
 All battery charging call for 2.37 <> volts per cells
6 or 12 volts batterys .
 In the bank with 30 cells dose this mean you need 71.1 volts
to charge the bank????
 O yes I picked up 5 batterys all read 6.26 to 6.27 volts
all less than a year old, all had 25% charge ,just lucky
« Last Edit: March 30, 2007, 12:53:10 AM by (unknown) »
Re: Hurricane Electric BATTERY TIME Part 2
« Reply #1 on: March 30, 2007, 01:05:32 AM »
That voltage seems reasonable but may need to change a bit depending on the type of battery. May be a bit high for some AGM, see if you can find the makers site.
If flooded cells then if they have been discharged for a while you may want to go a bit higher for a first equalising charge.
« Last Edit: March 30, 2007, 01:05:32 AM by Flux »
southpaw
« Reply #2 on: March 30, 2007, 03:10:22 AM »
If they are connected in series.
« Last Edit: March 30, 2007, 03:10:22 AM by southpaw »
kurt
    • website
« Reply #3 on: March 30, 2007, 01:34:30 PM »
why not just wire them like this
and charge them with a standerd 12v charger a 60v battery bank seems kinda silly for starting off. most people pick 12, 24, or 48.
« Last Edit: March 30, 2007, 01:34:30 PM by kurt »
