Author Topic: Solid fuel hot water system - anode types  (Read 2472 times)
domwild
« on: October 15, 2008, 07:24:59 AM »
Friends,
The types for sale here in Oz are aluminium with an inner core of steel, which is causing rusty water once the anode's alu has been eaten away.
Are there anodes for sale for a rainwater supply to the heater as distinct to the anodes for town water, which is more aggressive as it is chlorinated?
« Last Edit: October 15, 2008, 07:24:59 AM by (unknown) »
sdscott
Re: - anode types
« Reply #1 on: October 15, 2008, 10:52:53 AM »
Sacrificial anodes protect the voids in the glass lining of mild steel water heater tanks via use of magnesium/zinc or aluminum/zinc alloy anodes.   Magnesium is preferred, (aluminum, being lower on the Galvanic Scale than magnesium, provides somewhat less protection), but is more costly.  (Also, considering "the danger of food contamination by aluminum" this water is not for ingestion).
With stainless steel water tanks often no sacrificial anode is used.
Magnesium anodes should be used for soft water (eg. Rain) because of it's Galvanic index.
Replace the anode before you see rusty water or your tank is degrading (maximum life of rod - around five to six years). BTW, for a sacrificial anode to provide any protection, it must be in electrical contact with the metal being protected.
Cheers!
« Last Edit: October 15, 2008, 10:52:53 AM by sdscott »
Re: - anode types
« Reply #2 on: October 15, 2008, 04:51:28 PM »
Tap water from an US EPA regulated supplier (most everyone except trailer parks and very small towns in rural areas) is supposed to be slightly passive to protect the plumbing. We use aluminum sulfate (alum) to purify water and chlorine is forbidden now as a disinfectant except to purge the pipes once or twice a year.
ChlorAmines are used to disinfect, but it is corrosive to common rubber toilet flappers, so better grades of rubber are now common. Chlorine was banned because it reacts with trace organics to make compounds that may cause cancer. Ozone is also used, but sparingly because of the cost to make it. Reverse osmosis is also common, but costly, so it is reserved for water otherwise too salty for direct use.
In the US, water tanks with longer warranties simply have bigger sacrificial anodes. One of the disadvantages of aluminum is that it swells when it corrodes, so you may not be able to unscrew it to replace it. As long as you don't drink the water that goes through the hot water tank, the aluminum from the anode or lining shouldn't be a health hazard.
Just pull cold water from another source and heat it if you want to make tea or coffee, or cook with it.
Magnesium can give you the "runs" but it makes a better anode.
« Last Edit: October 15, 2008, 04:51:28 PM by dnix71 »
