Big time Copper 3 or4 strands of 14 with large mags .Your going to be see good efficiency
at 1200 rpm .That's if your wanting Dc load. You can take your pick 12, 24 ,36 ,or 48 . That's the higher amperage coil design. You didn't say what voltage you need. If you want higher Rpm or line voltage I think you should plan out a motor conversion. All that plastic is hard to keep balanced at 1.5 k or higher I've run a couple to 2k and some special balancing technique has to be employed.
