As promised, here are some pictures of mod's made to various components of my homebuilt mill to allow more airflow over stator and rotors and hopefully make overheating less of an issue, once tail vane size and weight are changed for proper furling. The following pictures detail the steps I've taken and each picture is captioned with what I'm attempting to show. All work was done by myself in home workshop.
![](http://usera.ImageCave.com/mgtd/jse_100_3951.jpg)
The front and rear rotors, blade supports have had their center holes enlarged to 3.00 inches to allow airflow around the hub (rear blade support hole enlarged to 3", front machined to 3". as the front was a flat plate). Performed on 14 1/2" Southbend lathe.
![](http://usera.ImageCave.com/mgtd/jse_100_3952.jpg)
Thr Dexter trailer hub was trimmed and trued, removing a small amount of the bearing carrier diameter and in the process cleaning up the rough casting at these points. The flat area of the bub's carrier is down to 2.450", tapered to the end, as original. Again to give more of an aperture for airflow. Performed on Southbend Lathe.
![](http://usera.ImageCave.com/mgtd/jse_100_3963.jpg)
Next the flange of the hub was indexed at 30 degrees and .040 slots were milled approx. 1/4" deep around the hub. Performed on Barker Horizontal Mill.
![](http://usera.ImageCave.com/mgtd/jse_100_3966.jpg)
At each slot, the rear side of the hub's flange was then milled to .200 thick to allow positioning of the blades without interference of the lug portion of the flange and to make blade fabrication easier, allowing a standard "nibbler" to be used to put the slot in the blade. Performed on Millrite Vertical Mill.
![](http://usera.ImageCave.com/mgtd/jse_100_3959.jpg)
Then, 12 blades were cut from .042 mild steel. Blades are 1/2" by 1", with a centered .200" slot, 1/4" deep. These were pressed into the hub's flange and then Mig welded in place, and the welds trimmed back to the flange's circumference. Blade slots made with "Nibbler" tool
![](http://usera.ImageCave.com/mgtd/jse_100_3967.jpg)
Here are the blades in position. Hopefully, creating a squirrel cage fan effect, forcing air inducted through the front of the blade and around the hub, over the stator and rotors.
![](http://usera.ImageCave.com/mgtd/jse_100_3972.jpg)
Here is the completed hub with welded blades, sitting in the rear rotor to check clearances.
![](http://usera.ImageCave.com/mgtd/jse_100_3973.jpg)
Here is a straight on view of the blades and hub/rotor.
![](http://usera.ImageCave.com/mgtd/jse_100_3989.jpg)
The jacking screws also needed modification (ends ground to tips) for clearance of blades during assembly.
![](http://usera.ImageCave.com/mgtd/jse_100_3977.jpg)
Here is a trial assembly with both rotors with about .625 inch gap for stator, again checking for clearances.
![](http://usera.ImageCave.com/mgtd/jse_100_3982.jpg)
Front view of trial assembly, showing approx. 1/4" gap for air induction.
![](http://usera.ImageCave.com/mgtd/jse_100_3984.jpg)
Here is the back of the hub/rotor showing same 1/4" clearance.
Not shown is the blade assembly with it's 3" hole, nor the bearing cap that will be installed on final assembly.
Material in these mod's was nil, though it did take the better part of a full day to accomplish the machining and fabrication.
Parts are being painted now.
My wire order should be here on Tuesday from Otherpower--Ester Vinyl and ATH are already here. A couple days to wind the coils and make a new stator and I'll be back in the air.
