The gap does include the width of the stator, I thought that's the way the air gap is measured. Sorry if I was mistaken. There is only a 1/8 inch gap between the rotors and the stator so unfortunately I can't get much closer and shrink the gap. I figured that since the total magnet width was 1 inch that a 1 inch gap would be okay.
Thanks for the kind words regarding the pillow blocks. However, it seems that the pillow blocks have gotten mixed reviews. In my previous post, Flux was questioning if they would be able to handle the load. I'm crossing my fingers though, so far so good. It has already been in 20+ mph winds and it appears to be okay.
I've tried charging both 12v car batteries and 3 - powersonic 4 volt 10ah AGM SLA batteries hooked in series. I noticed that the car battery takes higher amperage than the small AGM batteries. The car batteries took 8 amps but the highest amperage that I saw going into the AGM batteries was only around 5 amps. Perhaps they are too small to take the current. My plan is to buy much larger AGM battery, like maybe 100ah. I'm hoping that they will take higher charging currents.
