Below is a link to the progress I've made on a PM motor/Gen and some very basic but important facts about calculating power I've learned...
http://www.theworkshop.ca/energy/Wind/4/wind4.htm
I realize that this stuff isn't rocket science, but regardless of how many times that you read about other folks progress nothing comes close to making the mistakes yourself...
At present I'm looking for some guidance on selecting and sizing blades for the unit in the link above... It will need to spin in the 600 to 700 RPM range to generate 10 to 20 Watts... Is it realistic to oversize the blades for use on the next revision gen after this one? Or is the sizing and speed related such that each unit is unique in it's requirements....
I don't want to get too hung-up on indepth math, but certainly don't want to waste time on poor concepts or practices of blade design either...
Is there such a thing as a basic shape, twist and taper that fits most applications and will be semi efficient???
I have started the learning curve on TSR, Chord etc... but have no reference so it does seem somewhat abstract at this point... (the OP blade design primer was down last time I checked...)
Somehow I feel obligated to point out that my objective at this point is not to generate much power with these projects(obviously), but rather to learn how to generate power and scale as lessons are learned...
As always any assistance is appreciated...
