As I found easy to collect just some thinner/smaller parts off of a large electrical latice towers around my town, I start some planning.
At first, about my site. Maximum tree height is around 5 meters ( hundreds of meters around), and it is not near parallel to the sea-level (not many sites actually are). It's downhill, but pretty flat if you look up to the mountain or down to the valley, and even on both sides.
I plan to mount Hugh's 8' wind generator on the lattice tower, and maximum that it has to withstand is dan's 10 foot turbine.
My galvanized steel pieces are L-angled 50x50 mm ( 2"x2"), three meters long.
Also, I plan to mount photovoltaic panels around three meters high on the tower.
I plan to make some sot of a platform on the top of the tower, and above that to use some 2 meters long tube as generator mount (thicker-low and thinner-top).
I need design without the guy wires. It looks better to me, and it's not the problem to make a base large/strong enough for that, as we are starting to build a vacation house there, so lot of concrete is going to be spent there.
Any suggestions about the height and dimensions?
