My friend wants to install a turbine (or eventually two) at his place. We've been looking at the 10' complete Otherpower machine.
My friend already has a surplus tower that's square (four legs), made of heavy steel (I'll get pics and measurements tomorrow), but I'd guess it's 6"x6" angle iron about 3/8" thick and the tower is about 8-1/2 feet square (footprint) and 25 feet tall. My friend's idea is to weld some more 6" angle iron and crossbraces onto the bottom of the tower and make it about 35 feet tall, then orient the tower so one corner faces west, which is the predominant wind 90% of the time. He'd then like to add two 10' or so poles on top, on opposite corners (north and south) so the poles would be at the same height, but about 12 feet away from each other horizontally... with the idea that he could install one turbine now and another one at a later date, and if the wind comes from the west 90% of the time, one turbine would not block the wind for the other very often.
So I guess my question to the board here is... is this crazy enough to work without guying it? I'm not sure how he's planning to weld the poles to the top of the tower, (webbing, etc.) but he has plenty of steel and a good welder at his disposal. He also has machines (excavators, etc.) and good concrete to pour a big foundation (or four). I really don't know how much force a 10' turbine in a full wind will put on a tower, so I thought I'd see what you folks think... if this would work, how big of a foundation it would need, and if it's a VERY bad idea to fly two turbines on the same big tower...
P.S. Yes, my friend knows that he'd be better off putting a turbine on an 80' or 120' tilt-up, but he'd rather use what he's already got for now.
Thanks,
-N.
