The problem is not to get the genny to be disconnected until it's up to speed. In a battery-charging application that happens automatically:
- At speeds below "cut-in" the voltage generated is less than the battery voltage plus the diode drop, so no current flows.
- Once up to speed current starts flowing.
Until the current is flowing, a core-less alternator (like our homebrew axial flux machines) puts essentially no load on the shaft, while one with a core only applies a very minor drag from eddy-current and hysteresis losses. The main load is from the interaction between the magnetic fields from the output current in the coils and the field magnets, which steal mechanical energy from the shaft to provide electrical energy to the coil connections. This only happens to the extent that there IS a current in the coils.
The problem is to DISconnect the low-speed alternator when the speed is too high and to gracefully REconnect it when the speed drops (so you don't "slam on the brakes" and shock the spinning mill.)
We have played around with doing that electrically, making a two-speed "gearshift" by switching between Y and delta (or Y and Jerry-rig). Look up delta-Y switching on the board. A two-alternator system with the low-speed alternator disconnected by a clutch at high speeds would have exactly the same issues (plus mechanical problems from the clutch and the extra bearings and activation mechanism).
