Author Topic: I NEED HELP ABOUTH MY BLADE  (Read 3833 times)
tico
  • my first windmill
« on: May 31, 2010, 09:27:16 AM »
I need a computer to 1m blades.I have built a compact generator with 48 magnets
I am from romania and please excuse my English
 Is about 150 mm diameter generator and I need a sketch or account for 1m blades do not know other only metric measures
non
Re: I NEED HELP ABOUTH MY BLADE
« Reply #1 on: May 31, 2010, 09:41:12 AM »
tico;
This is as good an online reference as any for blade carving. By a master of the craft and a pioneer of home made turbines:
http://www.scoraigwind.com/selfblade/index.htm
It is in English but the pictures should be worth the time to look at.
Welcome to the forum and good luck on your project.
tico
  • my first windmill
« Reply #2 on: May 31, 2010, 10:15:44 AM »
this is the first blade model that i have built
 for me I need paddle diameter narrower and smaller in thickness should be like starting from 40mm
non
« Reply #3 on: June 01, 2010, 02:32:48 PM »
I'm comfortable with metric - can you give me more information?
How fast do you want your generator to be turned?
The "four foot diameter" plans on the Hugh Piggott website have a 1.2 meter diameter.  An excellent starting point.
If you want to try scaling that down to 1.0 meter diameter, then scale all of the others by the same factor.
tico
  • my first windmill
« Reply #4 on: June 02, 2010, 09:13:05 AM »
abouth 150 rot
blade must be like this
non
tico
  • my first windmill
« Reply #5 on: June 02, 2010, 09:16:47 AM »
abouth 150 rpm give me 12 volt
465-0
this is my rotor and you can see the scale
non
« Reply #6 on: June 02, 2010, 01:19:35 PM »
The blades in your picture are between 6 to 8 feet in diameter, or between 1.8m to 2m.  They look a lot like the Hugh Piggot design, but you want a size smaller than that.  2 meters is quite large for the size of disks you show in your second picture.
Assuming you have completed that generator now with several magnets and coils, then a rotor about 1 meter in diameter may be about the right size.
So I agree you are on the right track.
Try looking through the Hugh Piggott website more:
and look especially at these pages:
http://www.scoraigwind.com/liselotte/index.htm
http://www.scoraigwind.com/wpNotes/index.htm
You can try your own calculations with his spreadsheet:
http://www.scoraigwind.com/liselotte/spreadsheet.xls
tico
  • my first windmill
« Reply #7 on: June 03, 2010, 11:04:01 AM »
if girl can do this i try to make too
blades will be of linden wood
thanks
non
tico
  • my first windmill
« Reply #8 on: June 04, 2010, 03:28:55 AM »
My generator is calculated at 200 W
 I searched everywhere but information abouth human mistake guided me
 the principles you learn to be better can make the peaple better
 so I try to generate a positive effect on all who know me
2 generator is working and will post pictures will be finished after
non
« Reply #9 on: June 05, 2010, 12:43:15 AM »
I wish you success, and we look forward to seeing it progress.
