seems like you would have a low voltage output, [2 coils].per rectifier..
but a whole lota amps!!
if you want volts try single phase--hook all coils in series--n.s.n.s.n.s-and so on.
just hook a batt up when you connect your coils togeather--then hold a mag. over each coil,it should attract and then repell and so on..so are you using 10 mags as well?need 10 for single phase..10 mags 10 coils..or try 3 phase 9 coils 12 mags..
later.............
