I've been using a 3KW variac, a 2.5 hp 130 volt dc tredmill motor and a digital lazer tack for alt testing.
Sometimes I need to move the test stuff around in my shop but its big, bulky, heavy and a pain in the %^&* to move around.
So I thought I'd make a smaller lightweight unit for some of the smaller alt projects.
Harbor Freight has a router speed control (15 amps) but I missed the sale $12.95 now there back at $29.95. I did want to try this speed control but I didn't want to pay twice the sale price either.
So I went to Lowes. They have a 600 watt light dimmer for $4.83. So I thought well what the %^*# I'll try it.
The instruction said use with incondecent light bulbs only. Not motor or transformers or I guess anything inductive?
Well I use a fullwave bridge rectifier with the dc tredmill motor so I thought might isolate the dimmer from the motor.
It works great. I'm using a smaller 1.75 hp 100 volt tredmill motor on this setup.
I can very the voltage down to 13 v and up to 109 volts. Its strange just spinning the motor under no load the ac amperage going into the dimmer stays around 2 amps no matter what the voltage at the motor. Bogging the motor down the amperage will clim prety fast. This is a 22 amp rated motor.
I realized I would be puttting a higher than rated load on the dimmer so I took it out of it housing and mounted with heatsink compound to an old car amp heatsink to help it handel the added load and heat. I guess we'll see how it holds up.
Seems to work good though and the hole thing was prety cheap.
