That sounds ok, but you have 1/1 of the wind to drive 2/1 of gennie
Silly me:)
Seriousliy there are some problems with that, one being one balde of the same size will not give 2 windmills worth of power, so you don't acompliased the goal trying to put two mills together. Unless perhaps you made larger blades or a different type etc..
Still problems, more blades or larger blades might provide more torque but not more speed. Most likely I think they would run slower meanung you need more wind for the same speed, speed is what makes the power. Adding 2 mills together you will need both speed (same as 1 mill) and more torque because you are now driving 2 gennies instead of one. You still don't get double the power though. Maybe more power than one gennie, but not double, unless maybe you build a front dual rotor gennie, and a second dual rotor back further as 2 totally seperate units on one shaft.
I have given that some thought. Use like a double bearing jack shaft. Mount 3 blade prop and dual rotor at the front, a second daul rotor genie on the other end lined up exactly the same, then the 2 second 3 bladed prop would be turned so the line up in the center of the front blades. This would sort of give you both a 6 bladed prop and 2 3 bladed props at the same time in a way. If the blades are far enough apart it might not be too bad. Furling out of high winds would be a problem though since you basically have an up wind and downwind gennie on one shaft.
