Thanks everyone for replies.
Yes, I will be happy to share details from here on out. I have already built the alternator and have no pictures but will take pictures and show tower when it arrives.
I was hoping to grid tie, we are on an electric co-op which in Texas is not required to buy or compensate for electricity I generate. I have reached an agreement with them but, with just this one alternator and my electricity requirements I don't believe this will be economical until a second alternator is built.
Yes, I'm busted. I failed to read the fine print on the inverter. I thought the solar charge controller was included and usable for controlling the alternator. I also failed to realize the distribution center is extra. In my defense, I really wanted the inverter/charger to sustain the new battery I purchased until, as mentioned, tower could be raised. I will purchase these items with it if required but wonder if the outback system would be more suited? With some c60's or the like. I am wanting a split phase system, one less headache, for electric heat/wasting additional power. Sounds to me like the 3500 watt outback would suffice and I can piggy back as I add alternators to get the split phase.
I only have two acres at the moment and thought I better build a couple of 17's instead of a bunch of 10's. If this tower can be built as estimated, It will be free standing. Crossing fingers. I already have a 5ft by 6ft hole 12 foot deep for the tower. Half of this hole has been cemented with hooks and re-bar installed. the last 12 inches is supposed to have some sort of pad or ?. Once the tower is set and cement poured I'll be happy. Just hope it holds? Any thoughts. I'll have to wait to give particulars on the tower materials, I can't remember exactly but seems to have 3 legs with 4.5inch schedule 80 pipe but really can't remember anything else. I will rent a crane to install alternator. bummer. Just can't afford a tilt up or scope up. Money is tight.
As some of you might have seen, I've been lurking and reading this site for a while. I really respect this board. Thank you.
