> I got 4' 125 W wind generator with 6 coils 1.4mm dia/80 turns.
This phrase does not say anything about your voltage generated., someone may spend the time to calculate the output voltage, but even more info is needed to properly know what you have.
First: You need to inform what is the voltage of th e wind mill at the peak of the power where you need to connect the dump resistance.
Also, the current at that peak.
The resistor you have 70 ohms for 220 volts usage represents about 700 watts load.
You will not be able to take turns off, you will need to do selected short circuits to some sections to end up with the necessary resistance to protect your wind mill.
So, properly inform, in detail what you have -- accurately -- then what you need
Nando
