"Hobbico"
"Digital Mini-Tach" #HCAP0400
Hello, I have this mini tach from RC Combat flying Days gone by.
I'd like to mount this up on the tower pointed at prop/blade from behind/under.
I wonder if anybody knows how far I could move the little sensor, (how much wire I could add between it and diplay-readout)?
Unit runs on 6 VDC.
I'll run a power line up ,so I could add these wires also, but I'll need to, to add other idea's anyway. (Moveable video camera mounted under weathercover behind Ametek).
I'd like to be able to watch the RPM's while also seeing Amp's/Volts.
Right now only able to watch mill thru Security Video camera aimed at it, it's about the same as watching the street. JUST LIKE TV, a waist!!!
So if anybody has any thoughts or idea's....
please share
Thank you
