Author Topic: Wind for heating water  (Read 1513 times)
force9BOAT
« on: June 08, 2006, 09:03:01 PM »
Hello,
Many people on this board have said they use their wind turbines to heat water.  I'm thinking of doing that too but don't know anything about heating elements used.  Can anyone point me to information on wind turbine heating elements for heating water?
Thanks all,
Rob
« Last Edit: June 08, 2006, 09:03:01 PM by (unknown) »
  • Moderator
Re: Wind for heating water
« Reply #1 on: June 08, 2006, 03:12:46 PM »
Search "DC water heater element".  Some cost less than others!
« Last Edit: June 08, 2006, 03:12:46 PM by (unknown) »
powerbuoy
« Reply #2 on: June 08, 2006, 07:18:17 PM »
what type of turbine/generator do you have?
« Last Edit: June 08, 2006, 07:18:17 PM by (unknown) »
force9BOAT
« Last Edit: June 09, 2006, 11:28:24 AM by (unknown) »
« Reply #4 on: June 09, 2006, 01:57:35 PM »
How'd the vibration from that to-the-house mounting work out?
« Last Edit: June 09, 2006, 01:57:35 PM by (unknown) »
force9BOAT
« Reply #5 on: June 09, 2006, 05:27:04 PM »
That's a good question.  At first there was a real problem with the yaw bearing.  Anytime the wind changed direction there was a loud metal against metal grating noise that reverberated though the house.  I was able to completely eliminate that problem with a teflon pad on top of the mast and some grease.
The jury is still out on alternator vibration.  The first set of blades I built did not work very well and the machine almost never reached cut-in speed.  I'm in the process of making a new set of blades now that I expect to have mounted in about two months.  I'm also planning to cut down one tree directly behind the turbine.  Then I hope to get more vibration data (and I hope that is little or none).
« Last Edit: June 09, 2006, 05:27:04 PM by (unknown) »
« Reply #6 on: June 09, 2006, 11:38:57 PM »
the blades should be just about done , no?
in the last pic of them they looked just about done
« Last Edit: June 09, 2006, 11:38:57 PM by (unknown) »
powerbuoy
« Reply #7 on: June 10, 2006, 11:28:28 AM »
I am wondering if he could use a standard 120VAC heat element and just feed it with the variable cycle AC from the alternator???
« Last Edit: June 10, 2006, 11:28:28 AM by (unknown) »
force9BOAT
« Reply #8 on: June 11, 2006, 10:25:40 PM »
I might try that with a fish tank heater and see how well it works.
« Last Edit: June 11, 2006, 10:25:40 PM by (unknown) »
force9BOAT
« Reply #9 on: June 11, 2006, 10:27:43 PM »
I am almost complete with shaping the blades.  Things have been a little busy for me lately with my daughter graduating from high school and some traveling coming up.  I hope to have the new blades flying sometime in late July or August.
« Last Edit: June 11, 2006, 10:27:43 PM by (unknown) »
« Reply #10 on: June 12, 2006, 05:45:29 PM »
You need to be REALLY careful about vibration on a wooden structure.  Over time it will work the nails and other fasteners lose, just for starters.
« Last Edit: June 12, 2006, 05:45:29 PM by (unknown) »
