Been progressing with my Xantrex XW monitoring/logging software, it is coming along quite nicely!
Software has been working pretty well so I recently added the ability to interface to a Dataq DI148 D/A device. I incorporated the device into my software so that I can accurately monitor/log the turbine rpm's, I am using a door bell step-down transformer to bring the voltage down to about 5 volts.
This Dataq device is relatively cheap and comes with software drivers as well as support. Once I got some bugs worked out in my software I got the device working and tracking the rpm's very well, which caused some confusion.
It appears that my Mastech hand-held meter does not measure the frequency coming from the turbine properly, in the past I took the meter reading as gospel - but now highly doubt the readings.
I would watch the meter in higher winds and see that it displayed the fact that my turbine rpms increased from 125 (average) to up to 250rpm, measuring the same thing on the D/A device showed me that the rpm's only went from 125 to 150!!! So in the past when I reported rpm's it was based on the incorrect hand-held meter readings!
Just shows that you can't always trust what a meter displays!
Today we had a good wind blow through and in a 36mph wind I recorded a peak 250rpm with the turbine outputing 3.4kw output with 60 amps!
Dan Lenox
