after many years of waiting and planning it looks like my move back to kansas will become a reality later next year
my property is in the east central part of the state, in a decent wind area (cat3-4), the winds in summer are predominately
from the south and in the winter from the north as could be expected.
my property is on the north face of the largest hill/ridge in the area, and the centerline of the ridge runs east/west or perpendicular
to the prevailing winds. winds from the south have no obstructions clear to the horizon (perhaps 25 or more miles) and from the
north there is a little treeline down low on the hill, but probably the treetops are over 100ft lower than the top of the ridge.
i am aware how wind accelerates up a hill gaining speed, and have witnessed this phenomena on this specific hill, where if the wind is blowing
anywhere around there it is blowing like hell up there.
the average windspeed in the area is between 9.7 and 12 mph depending on the source you want to use, so i figure 10mph to be safe as
the average annual windspeed, and i figure the hill effect probably gets me closer to 18-20 mph average annual speed up on the ridge.
i plan on a tilt up tower of likely no more than 25-30 ft
my thinking is, if i were to go higher i would likely move above the gains in windspeed from the hill effect, and as i hate heights i am not sure
there would be any more to gain by going higher anyway.
the question is how high before you start to lose the hill effect?
and lastly about how much power can one expect from a 10 ft machine running in 18-20 mph windspeeds?
i don't need a lot of power 500 watts average at around 15 mph would thrill me to death.
also 30 mph winds are not out of the question in that part of kansas, also there are times that 40-50mph winds are pretty steady for
several days in spring and fall. i would assume that the hill effect would make for some real interesting speeds up on that ridge.
i will be installing a couple kwatts of solar panels, and really do not need to worry about low windspeed cutin, however i would like to target
for the 15-20mph speeds of the ridge, so maybe if i only need 500watts i can use a smaller rotor than a 10ft?
any suggestions?
thoughts and comments are welcome
thanks
bob g
