Author Topic: actual monthly / annual output averages versus rotor diameter  (Read 8359 times)
Fused
Re: actual monthly / annual output averages versus rotor diameter
« Reply #33 on: November 23, 2010, 03:52:45 PM »
Thanks to Hugh and SparWeb for the explanations.
It bothered me a bit so I looked into it myself.
I found the 8 footer runs a 2" larger diameter disk than the 6 footer
and that the 6 footer runs 1 magnet disk and 1 steel plate.
 I built the 6 footer and had it at first assembled with 1 steel rotor and 1 magnet
 disk, then I added magnets to the steel plate to have 2 magnet rotors. Output
went way up. Stator was wound with 20 ga.
I think I'm just trying to figure out how to justify building the 8 footer to my wife.  ;D
Thanks guys.
Fused
bvan1941
« Reply #34 on: November 23, 2010, 04:31:14 PM »
Dan B,
Thanks for the 20' turbine update. 200-600kwh/mo. is substantial !
Have you felt the furling of the 2 largest turbines have been reliable over the past 2years?
Would you contemplate building anything larger based on this design?
Bill
DanB
    • otherpower.com
« Reply #35 on: November 23, 2010, 05:50:48 PM »
Dan B,
Bill
Hi Bill - larger, no - especially for a battery charging system.  Honestly I do not know (and have my doubt actually) that my 20' machine would hold up on a really good wind site with high/steady winds.  So at this time, I have no plans to build larger...
The furling does seem to work well though, on the two that we have built.  They are pretty well limited to 3kW sustained output - I see occasional / brief peaks upwards of 3x that much.
