Author Topic: Snap Disc Thermostat  (Read 5794 times)
wewantutopia
« on: September 28, 2011, 02:27:04 PM »
Hi Guys,
I am redoing a solar air heating panel I made 2 years ago now I've learned a bit more about their dynamics etc.  I plan on adding a close on rise snap disc thermostat and wondering which you would go with
close 120*F  open 105*F http://www.amazon.com/Senasys-120%C2%B0F-Fan-Style-Snap-Disc-Switch/dp/B0026RTEZC
or
close 100*F open 85*F  http://www.amazon.com/Senasys-100%C2%B0F-Fan-Style-Snap-Disc-Switch/dp/B0026RYU4W
I am looking at these mostly because I can do 12v or 110 with it.
Thanks for the input!
Woodstock, IL 60098
kensue49
Re: Snap Disc Thermostat
« Reply #1 on: September 28, 2011, 05:33:39 PM »
wewantutopia
« Reply #2 on: September 28, 2011, 07:02:36 PM »
Thanks for the link.
Will that work will 12v computer fans?  It says 120/240v
Woodstock, IL 60098
« Reply #3 on: September 28, 2011, 07:11:18 PM »
At 12 volts and miniscule current like that I would use them. Trouble starts when they make / break circuits that draw a lot of current and it pits and carbonizes or welds the contacts drawing arcs when it cycles..
But then I like to do stuff differently and am comfortable messing with this stuff.
« Reply #4 on: September 28, 2011, 11:19:11 PM »
Might even consider a generic thermostat from a big-box store.
Trigger temp and 'anticipation' (Delta T?) are adjustable.
I helped CmeBrew set one up a while back.
Might find it with google.  It's somewhere on Gary's BuildItSolar, and CmeBrew posted it here mayybe in a diary (IIRC).
