Hi All,
I have been reading on this board about the wonderful Ghurd controller.
However for me getting the parts here in my city (Thane, Maharashtra, India) had been a problem.
I then searched for similar circuits based on NE555 and found this one.
http://gorum.ca/lvdisc.htmlI built it and seems to be working fine with a setup comprising of below.
12V Battery 60Amp-Hr capacity
One number 14-18 V 60 Watt solar panel directly connected to battery.
The circuit built as per the details in the link above in my case uses STP55NF06 mosfet to switch on and off a load which is nothing but a automtive head lamp bulb 24V 100 Watt rated.
During daytime there is no load on the battery and also no MPPT for solar. At night time I use the battery to power the LED lamps approx 12Vx3Amp load for 6 hours.
So say 18 AmpHrs are drained from the battery everyday and say 20-30 AmpHrs pumped in by solar panel during day time when in healthy sunlight.
After about 11:00 HRS I see that the lamp starts a cyclic switch on-off sequence until about 15:00 HRS [cycle time 8 seconds on then 12 sec off], for rest of the daytime the lamp remains OFF.
I have not installed the capacitors C1 & C2 (becos I could not get low-leakage tantalums) as mentioned in the circuit.
I request comments from the seniors here, about if the said circuit is meaningful generally or not and any improvements recommended.
The main aim being to prevent battery overchanging, a dump load contoller basically.
Observed setpoints after whatever tuning/calib I could do are at 13.50 [load turns off] and 14.50 [load turns ON] volts.
Prasad
