Author Topic: elevated weight as storage for generator?  (Read 15992 times)
MAL
Re: elevated weight as storage for generator?
« Reply #33 on: February 06, 2013, 10:43:57 AM »
How does the gravity light concept translate with 25 ton block of weight.  A hydrolic lift could easily elevate 25 ton in short order with minimal energy cost, but would it produce any significant power. If I understood the math I would figure it my self, but I am kind of new to this.
madlabs
« Reply #34 on: February 06, 2013, 11:20:21 AM »
I've been meaning to make a light for my outhouse. I was planning on a bank of super caps and a solar panel to charge 'em. Now though I'm leaning towards a steam punk wind up or weight based thing. It's a perfect place for such a silly contraption as one only needs a few minutes of light at a time.
Hmmm, now where to find some old clock/industrial mechanism....
JOnathan
dbcollen
« Reply #35 on: February 06, 2013, 11:51:34 AM »
You will ALWAYS get LESS ENERGY back out than you put in to raise the block.
Larsmartinxt
  • Country: no
« Reply #36 on: February 06, 2013, 01:32:04 PM »
Same thing applies to battery charging. Don't know what's more efficient.
I know that here in Norway we have some hydro power plants that pumps water up to the reservoir when there is a surplus of energy and then uses it when there is more demand.
http://en.wikipedia.org/wiki/Pumped-storage_hydroelectricity
MAL
« Reply #37 on: February 06, 2013, 09:05:37 PM »
I guess I am not being clear enough.  you could lift the block with a Chain block,chain pulley block,manual hoist by hand without using any other source of power.  http://www.alibaba.com/product-gs/207124635/HSZ_A_type_Chain_block_chain.html   But that is not my question.
 How much electricity can be generated by dropping a  25 ton weight 10 meters?
« Last Edit: February 06, 2013, 09:10:56 PM by MAL »
« Reply #38 on: February 06, 2013, 09:36:04 PM »
0.618 kwh
25 tons is 50,000 pounds.
10 meters is 32.8 feet
That's 1.64 million foot pounds
1 foot-pound is 3.766 x 10^-7 kilowatt-hours
« Reply #39 on: February 06, 2013, 10:17:38 PM »
i like the steam punk outhouse idea.
what about a method to heat up the seat for just a few minuets.
MAL
« Reply #40 on: February 06, 2013, 10:33:41 PM »
0.618 kwh
I don't think this idea will work very well  ??? Thanks for your knolidge
madlabs
« Reply #41 on: February 07, 2013, 10:51:39 AM »
Electron, a seat heater would be awesome! I live where we only get 20 or 30 days of frost a year, but still... That is gonna take a lot more energy storage than a light though.
Went poking around in my junk pile yesterday but didn't find anything with cool gears and so on. One bummer about living in the sticks is no good industrial junk salvage. I'll go to the flea market this weekend and see if I find anything.
Jonathan
keithturtle
  • Things that fly
    • aftertherapture
« Reply #42 on: February 08, 2013, 01:12:36 AM »
Big Ben?
Turtle
soli deo gloria
spottrouble
« Reply #43 on: February 14, 2013, 12:18:40 AM »
The Steam Punk outhouse light idea intrigued me too, today I think I found the gear drives, just got done opening one up, I think it will take 2 of these to get input rpm down slow enough to last 5 or more minutes, hmm, maybe try 3. They were from some type of rolling door brake, the faster door tryed to roll the faster final drive spun causing shoes on the final drive to fling out and rub housing. For the initial drive I was thinking of using the crank hub from a bicycle (just center hub), that way it would freewheel as you pulled free side of the chain, then the weight on other end of chain could drive gears, hmm, kinda hard to explain, hope one of you understood that.
Kristi
thirteen
« Reply #44 on: February 16, 2013, 03:38:58 PM »
If you have the storage and water and some sun install a solar pump for the water or a ram pump for the water then release it when it gets full for power. looks ok but not very efficant. just a thought. 13
MntMnROY 13
