THANKS a lot for your help! the magnets are 30 mm x 3 mm. OK so the coil creates a flow of electrons simply because it is charged by a shift in the magnetic field that the coil is exposed to (and the speed of the change of the state of the coil).
If the magnets are reversed every other magnet... then I should also reverse every other coil? (start - tail / tail - start / start - tail / tail - start/ etc) ?
Yes, I am using a identical second rotor with magnets such that the coils are sandwiched between the disks on either side.
I made one before and it failed because I stupidly used about 300 turns. I am not sure if I got it right as i did not start - tail / tail - start / start - tail / tail - start/ etc the coils ? QUESTION is why are the coils connected start - tail / tail - start / start - tail / tail - start/ etc AND is it that either the magnets or coils are reversed every other one or BOTH coils and magnets are reversed every other one?)
Sorry this probably sounds so simple and I'm not getting it.
There are 80 magnets in a 12" disk brake drum (on each one of the disks) (the coils are stationary in the center, and the magnets magnets move)
Its designed to move very slowly and still output over 13 volts. It only will output the small weight of the water volume.
An axle is seated on two sides of a square box in a bearing and the disks are bolted to the axle. The divider of the square box holds the coils. This is clever because it allows for adjustment of all the tollerances and is strong. The square box also provides the housing of the unit from weather, insect nests, or dirt/debris. The brake drums are brought down close to the coils by means of adjusting the bolts that hold the brake drums to axle. (The axle itself is a long screw/bolt).
Im almost getting it and after all this work I feel its going to work great and be a nice 24/7 efficient use of many thousands of gallons of water falling three feet. The wheels will catch and hold the water as it falls.
I've really spent a lot of time and got ice issues solved and other issues solved and its almost a finished device, Just don't want to goof it up again because I don't get some fundamental principle of electricity right.
Thanks again for your help, its helping and you guys are understanding me.
Its a simple device made of plywood and epoxy. I have never heard of or seen this configuration of rotors/housing and hope to post a picture for the collection. Probably you can get a picture of it as its very simple. It is also less maintenance being simple.
By the way I just got 1000 nice 6 inch polycrystalline cells on ebay - so its kind of like "why do i need that 1 amp water wheel"? Well, because its so close to being a nice piece of craftsmanship probably that I want to see through after all the effort so far. And the relaxing sound of it quaintly going pppsh - pppsh - pppsh over there in the background.
