Author Topic: morningstar remote temp sensor  (Read 820 times)
danda
« on: July 31, 2022, 02:27:48 AM »
I just bought a morningstar ts60 and was a bit disappointed to learn it does not include a remote temp sensor in the box.
I will probably end up buying one, but before doing that, I had another thought.
Could I not use an RTS I already have, either from a trace/xantrex c40 or a midnite classic?
iirc, both of those rts have some kind of male plug, eg rj-12.    But I believe only two wires are actually used.
The morningstar has no plug, it just has two small lugs for two wires, and the manual says that the polarity does not matter.
So, I'm wondering what would happen if I just snip off the plug, probably from a c40 sensor (cuz I have spares) and wire it in.
crazy idea, or crazy like a fox?
bigrockcandymountain
Re: morningstar remote temp sensor
« Reply #1 on: July 31, 2022, 08:06:11 AM »
I'm pretty sure the rts for the morningstar is a ntc thermistor 10k.  Look up the chart for a ntc 10k thermistor and then check the resistance across the wires of the xantrex one you have.  They are probably the same.
10 000ohms at 25c
12 494 ohms at 20c
15 814 ohms at 15c
Hope that helps.
danda
« Reply #2 on: August 02, 2022, 03:36:54 PM »
thx for this.  I will check it out.
