So, after almost 6 weeks of continuous work we have a set of blades and a 'recipe' on how to manufacture them fairly easily varying parameters like 'tsr' and 'taper' to create a cnc cutter program that then automatically produces the desired blade.
I know a lot of you must think these guys are nuts, I could have done that in a few days, and you'd be essentially right about that, making three blades should not normally take 6 weeks. But our side of the story is that we also developed the software that models these blades and that simulates their manufacture. That software works for any airfoil (in fact for any complex surface) and will produce a new shape in a matter of hours, without any marking or manual labour.
As long as you don't mess up your filenames (which I managed to do the day before yesterday, ruining one perfect blank) everything goes by itself and the shape will come out exactly as specified.
So, the upshot of that is, if you you just want a set of blades then it is probably faster to whip our your chisel/grinder/axe/chainsaw/insert favourite chip producing tool here, but if you want to be able to make a lot of blades or many small variations on the same set of blades then the extra work that we have done will pay off. In order to produce these three blades we have also made - and discarded - about a dozen test blades, each of them subtly different from the previous one, homing in on the final shape.
As I have said long ago, I would like to make these blades in foam, because it's cheap and very easy to work (no roughcut, you can immediately cut your final shape), but the problem with foam is that you have to attach it to the rest of the machine somehow and that is not a trivial problem.
So, for now these wooden blades will be what we will be using.
Fibreglassing or not was a question for a while, but we ran a small test to see what the stiffness change in the blade would be after fibreglassing it, and coated a small piece of wood with two layers of fabric on each side and kept a similar piece uncoated.
Then we hung identical weights to the ends of the pieces of wood and measured the deflection.
The thin fibreglass coated piece is more than twice as stiff as the untreated piece !
That's a lot of extra stiffness gained for a minimal weight penalty, so we will be going that route in the next few days, stay tuned !
Pictures follow:
The three blades side by side. They are still in their 'webbing', left over from the blank that they were cut out of, to protect them from damage.
Closeup of the 'root' portion of the back of each blade. Notice the improved section at the root, this is much stronger than before now.
Closeup view of the two test pieces for the fibreglassing test. The left one is the 'glassed' one, the right one is plain. The weights are suspended from the wires. In the 'neutral' position (no weights) the pieces of wood are level with the top of the measuring tape.
An overview picture. (hope your shop is not as messy as mine
