Author Topic: Fixing lawnmower with Solar Power  (Read 1692 times)
« on: July 09, 2005, 08:01:22 PM »
....sure enough...no spark....Well of course not,
not after the previous owner kept storing it
under the porch after mowing season.
  I might add this doesn't do the paint job on
the lawnmower any good either....stuff peeling off
like a bad wallpaper job!
  So I simply took the coil off laid it on top
of an old black gas grill cover in the sun from
8AM. to 11AM nice and warm...stuck it back on
...took the piece of coat hanger wire that someone
had put on the governor..so they could beat down
the weeds with a dull blade with all 4.5 horses!
Brilliant!
  Anyway in conclusion once I tune up the
carbuerator and readjust the governor I'll have
a nice running  LawnBoy (they run nice and
quiet, like an outboard) just by giving the coil a nice
little sunbath ...this is the second LawnBoy that
I fixed this way. So if you got a coil that
doesn't work...give it a try it's sure cheap
enough!
               ( :>) Norm.
« Last Edit: July 09, 2005, 08:01:22 PM by (unknown) »
Old F
Re: Fixing lawnmower with Solar Power
« Reply #1 on: July 09, 2005, 04:53:03 PM »
With my luck it would work then it would hold out
for a full spa tretment : )
Old F
« Last Edit: July 09, 2005, 04:53:03 PM by Old F »
tinker
« Reply #2 on: July 09, 2005, 07:27:15 PM »
My luck, would contact a lawyer and sue for willingly and knowingly exposing said same to harmful solar ultraviolent radiation resulting in a cancerous condition whereby extremely high voltage discharges are experienced whenever excited by passing magnetic fields =O
« Last Edit: July 09, 2005, 07:27:15 PM by tinker »
« Reply #3 on: July 09, 2005, 07:38:46 PM »
  Well Mostly if I was selling it I would tell the guy not to store it under his porch I prefer a good old Briggs myself never ever had that kind of trouble with them....
               ( :>) Norm.
« Last Edit: July 09, 2005, 07:38:46 PM by Norm »
« Reply #4 on: July 09, 2005, 08:25:36 PM »
My daughter is getting her drivers license.
My briggs mower is older than she is.
I have less trouble getting the briggs to work! LOL
« Last Edit: July 09, 2005, 08:25:36 PM by ghurd »
« Reply #5 on: July 09, 2005, 11:45:59 PM »
i just toss my mowers under a big spruce tree in the fall--always fire right up in spring..just a couple of old briggs and stratt. mowers--still have the old point system in them--to clean the points you have to take the flywheel off--only do that once in a great while.........later..
« Last Edit: July 09, 2005, 11:45:59 PM by hiker »
« Reply #6 on: July 10, 2005, 05:50:50 AM »
 Hiker,
   I used to fix lawnmowers, (for fun and profit)
One of my customers told me that after they hit
a large rock the mower had quit, so I told them
they probably sheared the flywheel key and it was
out of time....'how do you fix that?'
'you have to take the flywheel off and put in a
new key'...bring it in tomorrow and I'll fix it
for you'
  'Nah ! ...sounds easy enough I'll do it myself
 Next time I see him...'Well get the mower fixed?'
  'Nah ! couldn't figure what held the
flywheel on thought maybe it was a press fit
so we(his brother) used a wheel puller...'
  They got the flywheel off ....most of it....
except the hub and the starter clutch (Briggs)
  To make matters worse they threw the whole
thing away after that.....me with about a dozen
flywheels on the shop wall to fit it!
               ( :>) Norm.
« Last Edit: July 10, 2005, 05:50:50 AM by Norm »
Experimental
« Reply #7 on: July 11, 2005, 09:44:18 AM »
       OH Yah,
      And usually, those flywheel keys are made of aluminum, and even if they are only slightly "dented", they throw the timing off, enough to make them very difficult or impossiable to start !!
      I told a friend this, he removed his flywheel, and sure enough, that was the problem -- he then made an "improvement", with a steel key !!
      The next time he hit a rock -- it broke the crankshaft !!!
     The moral of the story -- Don,t use steel keys !!   Bill H......
« Last Edit: July 11, 2005, 09:44:18 AM by Experimental »
phil b
« Reply #8 on: July 11, 2005, 11:09:10 AM »
BTW - it only takes a nick on that alum key to render it useless. If you keep shearing keys use valve grinding compound to restore the taper. :)
« Last Edit: July 11, 2005, 11:09:10 AM by phil b »
Phil
BT Humble
« Reply #9 on: July 11, 2005, 04:10:02 PM »
That happened to my B&S mower too, and I was so proud of myself when I figured out what was wrong with it without having to ask anyone! ;-)
I also decided that repeatedly pulling the ripcord to start recalcitrant motors was a good job for someone else, so these days if it doesn't start after half-a-dozen pulls I put a socket in my electric drill and spin her over real quick. >;-D
BTH
« Last Edit: July 11, 2005, 04:10:02 PM by BT Humble »
« Reply #10 on: July 11, 2005, 06:46:51 PM »
  He should have used an air key !
  Air keys are easy, cheap, convenient and never
wear out!
  No ...I'm not pulling your leg...a flywheel key
is just a locator...the trick is to make sure it
stays there until you torque it down to specifications.
  I had one old briggs that I had just cleaned the points and couldn't find a replacement key
and the store was closed... so ever since then
that particular motor got it's points filed
every spring tune-up ....but ran keyless !
  If you hit a rock the air key will shear just
as easy as an aluminum one !
                   ( :>) Norm.
« Last Edit: July 11, 2005, 06:46:51 PM by Norm »
Kwazai
« Reply #11 on: July 21, 2005, 11:28:19 AM »
when I sheared one I drilled and tapped for a bolt (3.5hp) and retarded the timing just a little in the process-always started a lot easier after that...
« Last Edit: July 21, 2005, 11:28:19 AM by Kwazai »
