Author Topic: High amp load tester.  (Read 1584 times)
« on: October 09, 2005, 02:22:47 AM »
I built this to test the 6 volt golf car batteries in my E-car.
Hope thi pix work? I've got a new camera and not sure how to us it yet. I think I need to reduce the megapixels?
« Last Edit: October 09, 2005, 02:22:47 AM by (unknown) »
Diferant camera stting next time?
« Reply #1 on: October 08, 2005, 08:28:33 PM »
Sorry if these pix are hard to load I'll try another setting next time?
« Last Edit: October 08, 2005, 08:28:33 PM by Jerry »
Re: Diferant camera stting next time?
« Reply #2 on: October 08, 2005, 09:55:13 PM »
hey wheres the bread--looks like a cool toaster...;}
just turn your camera down to its lowest setting..on mine it has between one and a five star setting --i always use the one star setting and they turn out great...
sure was a great summer up here--cooling off now --low 30s at night...
dang broke a pin on my spare  harddrive and now it dosent power up even thou i sodered the pin back on--lost all my dig, picts,--2 years worth--campin -hikin -and all the rest....must be a way to get them out of there????????????
guess i kinda got off the subject..........later.
« Last Edit: October 08, 2005, 09:55:13 PM by hiker »
Re: High amp load tester.
« Reply #3 on: October 09, 2005, 12:42:54 AM »
What are the coils out of?
I notice a $3 meter still came into use. I love those things.
« Last Edit: October 09, 2005, 12:42:54 AM by ghurd »
drdongle
« Reply #4 on: October 09, 2005, 07:57:49 AM »
Are you using the factory built shunt to calibrate you home built one?
« Last Edit: October 09, 2005, 07:57:49 AM by drdongle »
« Reply #5 on: October 09, 2005, 10:57:30 AM »
Hi Dr D.
Yes...my son purchased a new 400 amp meter and shunt for the e-car. I hadn't installed it yet and this more pressing mater of bad batteries came up so this is a temperary home for the meter.
I think I'll buy another meter though. This thing is very handy.
« Last Edit: October 09, 2005, 10:57:30 AM by Jerry »
« Reply #6 on: October 09, 2005, 11:07:43 AM »
Hi G.
The coils are from an electric furnes eliment. They were 50" long (25" bend X 25").
The total rating was 240 volts at 3400 watts. I just cut it up in 2" lingths and then used those littel braeker box ground strips with the hole and set screws.
These are screwed to the 1/4" X 1.5" copper bars. There are 3 sections so load amounts can be changed by removing sections.
The HF meter tracks voltage. I didn't have enough 4/0 welding cable for the test leads. I had some 3/0 though and it works fine.
« Last Edit: October 09, 2005, 11:07:43 AM by Jerry »
« Reply #7 on: October 09, 2005, 11:14:44 AM »
Have ya seen any snow yet? I've got one of my gennys flying in WhiteHourse.
Is that as far north as you?
All your KOOL wind genny pix are here on the board. So atleast we havn't lost those.
Sometimes puters are freinds sometimes puters are %&**#)":{T.
« Last Edit: October 09, 2005, 11:14:44 AM by Jerry »
