Author Topic: 6 inch dia. Zubwoofers  (Read 1131 times)
bug bit
« on: November 03, 2005, 12:25:34 AM »
I ended up with a 4 foot long section of 6 inch thick wall pvc tube ( .300" wall thickness above/below ground ). Using Zubblys program to get sizes, I cut out a really nice looking prop. It balanced great and didn't warp a bit. When I mounted it up and turned it into a 20-25mph wind blowing right off the lake, it just sat there. even when I grabbed it tnd spun it, it would stop. All I can figure is the tube is too thick? I have a 3 foot blade made out of 3 inch pvc that goes to a blurr when there is just a little breeze. Any thoughts on what I did wrong here?
« Last Edit: November 03, 2005, 12:25:34 AM by (unknown) »
henjulfox
Re: 6 inch dia. Zubwoofers
« Reply #1 on: November 02, 2005, 06:50:43 PM »
A picture might help.
Only way I can think of that a 4' blade wouldn't turn in a 20 mph wind would be if
you accidently cut it so that the pitch of the 2 sides are opposing each other - one
half is cut to turn clockwise and the other half cut to turn counterclockwise.
-Henry
« Last Edit: November 02, 2005, 06:50:43 PM by henjulfox »
georgeodjungle
« Reply #2 on: November 03, 2005, 01:55:08 PM »
or
is it mounted the same as the 3' x 3"?
to big of a motor or generator will do it, with a to small of a prop.
kills low speed start up.
« Last Edit: November 03, 2005, 01:55:08 PM by georgeodjungle »
bug bit
« Reply #3 on: November 03, 2005, 04:25:09 PM »
both have been mounted on a small cooler motor i put magnets to. 4 coils, 4 magnets and very litte resistance. the small blade spins like heck, i figured the bigger blade would do the same.
« Last Edit: November 03, 2005, 04:25:09 PM by bug bit »
« Reply #4 on: November 03, 2005, 11:31:08 PM »
 6 inches is pretty small to catch the wind. You should also round the leading edges and sharpen the trailing edges on a prop this small. you would also probably need some pretty strong angles too, maybe a hub angle of 45 degrees and a tip angle of 22 degrees.
« Last Edit: November 03, 2005, 11:31:08 PM by wooferhound »
« Reply #5 on: November 04, 2005, 06:27:20 AM »
Seems some guys are mixing pipe dia and blade dia.
I'm no expert.
If they are anything like the ones I played with,
The 4' of 6" blades should start easier than the 3' of 3".
I would not expect the thickness to be a very bad thing.
Even the ones I really mangled started OK.
My worst ones started to show problems at maybe 60RPMs.
The only thing I can think of is a problem with the gennie end.
Maybe the extra weight on the bearings? Or bending the shaft to bind the bearings?
Maybe a short in the gennie?
Is there a output load with the 4' that was not there with the 3', like a light bulb to act as a brake?
Maybe lay it flat, blade facing the sky and see if it spins free,
then try blade facing the ground.
Maybe take it in a quiet house and listen for grinding or other evil noises as it turns.
Let us know,
« Last Edit: November 04, 2005, 06:27:20 AM by ghurd »
