Author Topic: A mini motor for a mini mill  (Read 1003 times)
maker of toys
« on: November 29, 2005, 02:09:29 AM »
So I got to thinking about ghurd and Zubbly when this crossed my bench at work;  seems like an ideal candidate for a conversion sized to about a 2' diameter prop.
P/N: C25CHY-1 (yes, that's a penny there in the photo.)
they're rated for 115V, 1 ph, 60 cycle, 1000 RPM, 0.07 A  (thats not a typo) They're made by 'Eastern Air Devices', and run quite happily on 1 phase with a 1uF cap on the third leg. As far as I can tell, the windings are actually 3 phase, despite what the nameplate says.
the bearings are a couple of 608Z units; the rotor isn't much bigger in diameter.  The windings look like about #36 wire; I wasn't patient enough to try and count the turns.  The case is finned aluminum TENV, but I wouldn't call them completely weathertight; some good tape would probably fix that.  I can't wait for one to eat itself so i can do some experiments. . . <G>
 I checked the website: http://www.eadmotors.com
and this jewel is about the middle of the line; a 'size 25'.  they sell them all the way down to size 10.  (you won't find this exact unit in the catalog; it's had some special treatment. . .)
-Dan
« Last Edit: November 29, 2005, 02:09:29 AM by (unknown) »
Re: A mini motor for a mini mill
« Reply #1 on: November 29, 2005, 08:08:42 AM »
Too easy!
Big fun!
The ones about like that I did have 2 sets of windings, start and run.
The wires are too small to seperate... for me.
I only seperated the starts from the runs.
Test the lead to lead ohms, say 50, 100, and 150 ohms.
The 150 ohm reading is from a single end of both sets (red to blue?)
The other (black probably?) goes to both windings, 50 ohms to one wire, 100 ohms to the other. About like a center tap.
Carefully snip string and paper to find the end of the end where it is connected to 2 wires. Cut only one. Add an output wire to the coil wire just cut loose.
Now there are 4 output wires, 2 seperate phases, to be rectified seperately.
Turn or machine the armature for 6 magnets, N-S-N-S-N-S.
Do somekind of decogging measure, because it'll cog!
Don't glue the magnets down until the cogging is fixed.
A 2 liter bottle cut flat and twisted like a funnel helps get the rotor in without damage.
Expect some extreme voltage (over 100VAC) at low RPMs, but a very low amps.
« Last Edit: November 29, 2005, 08:08:42 AM by ghurd »
