i dont see ...... driving wide open-burns more fuel..
Driving wide-open does burn more fuel, but it also generates more power. If driving wide-open consumes double the fuel but means you only need to have the engine working for 40% of the time, it's still be a win. Evidently it is. :-)
Given the air resistance goes up as the square of speed, and so the energy per mile overcoming air resistance goes up linearly as speed, for a car to give the same MPG at 30mph and 60mph is evidence that the engine is only 1/2 as efficient at 30mph as 60mph.
My understanding of the mechanism is that the pistons extract energy from the burning mixture by expanding it and so lowering its pressure. When the mixture's pressure approaches that of the atmosphere, no more energy can be extracted -- the same force is on both sides of the piston. So the higher the starting pressure, the greater fraction of the energy can be extracted.
The throttle lowers the pressure of the mixture in the cylinders -- so best efficiency is with the throttle wide open.
driving in high gear and slipping the clucth to take off-surprized you didnt throw a rod throu the crankcase..lugging down your engine is hard on all kinds of parts..
I wasn't slipping the clutch to take off (any more than usual), I was using the clutch to disconnect the engine for most of the time, and leaving it to idle. Think of one foot on the floor or the other, but never both. When taking off I'd select a low gear (normally first) and floor it.
The thing I'd be most concerned about when driving at low revs and wide throttle openings is oil pressure, especially as the engine is over 100,000 already. But then, if I broke it -- the engine is over 100,000 already. I'm talking about a beat-up old 4WD with outrageously disreputable bodywork that I paid £400 for and intend to break for parts -- but not engine parts.
As you say, I'm better off "driving sensible", and that is what I'm doing now the experiment is over. I just wanted to see if it would make a difference, and if so, how much.
It does, and a lot. So I've convinced myself that my understanding of engine efficiencies is correct, and that I know how things like the Prius work.
I don't imagine myself driving like that again, except possibly if we have another fuel strike. But in a few weeks, now the weather's warmed up, I'll get the kitcar electrified and the Samurai can become an occasional use vehicle.
