Author Topic: CMI PM Motor  (Read 4237 times)
coldspot
CMI PM Motor
« on: February 25, 2006, 05:01:10 PM »
Controlled Motion Inc.
This PM Motor, i got off E-bay $0.99
NOT what I expected.
Freight was $24.
28 Lbs!!!
Even after stripping off the "Control"
on the rear end, It's beyond my scales 5,000 gram Max.
The output? wires don't show anything when turned by hand.
So I took it all the way apart, nothing seems wrong or damaged?
« Last Edit: February 25, 2006, 05:01:10 PM by (unknown) »
$0.02
coldspot
Re: CMI PM Motor
« Reply #1 on: February 25, 2006, 10:07:07 AM »
Some pictures of it
I hope to able to make use of it,
my first, New Hub" plan was a 5 blade that fit's this one.
« Last Edit: February 25, 2006, 10:07:07 AM by coldspot »
$0.02
drdongle
Re: CMI PM Motor
« Reply #2 on: February 25, 2006, 10:12:50 AM »
Cant read the name plate
tell us the specs
« Last Edit: February 25, 2006, 10:12:50 AM by drdongle »
Re: CMI PM Motor
« Reply #3 on: February 25, 2006, 10:33:59 AM »
You are testing for VAC, right?
« Last Edit: February 25, 2006, 10:33:59 AM by ghurd »
coldspot
Re: CMI PM Motor
« Reply #4 on: February 25, 2006, 10:37:29 AM »
Thats part of the problem
Name plate info is lacking any spec's
CMI, Controlled Motion Inc.
Plymouth, MN
Part No.   643-206
Model No.  ECM 643c
Serial No. P1032
Date Code. 1687
Customer No.
Revision level.
Thats it.
Nothing more
From Ohm Testing
Green wire to chassis ground screw
b&w= 3.7
b&r= 3.9
w&r= 3.4
El-Cheap-O multi meter seems to work better than
20 year old "FLuke 23", for Ohm testing??
On fluke
b&w= 6.4
b&r= 5.2
w&r= 4.8
Anyway thanks for looking
« Last Edit: February 25, 2006, 10:37:29 AM by coldspot »
$0.02
Re: CMI PM Motor
« Reply #5 on: February 25, 2006, 10:39:31 AM »
Is it really a permanent magnet, if that rotor was magnetic your tape in the last picture would be stuck to it. If it is magnetic then check for ac as Ghurd said.
I am not sure it is a pm.
« Last Edit: February 25, 2006, 10:39:31 AM by Flux »
coldspot
Re: CMI PM Motor
« Reply #6 on: February 25, 2006, 10:41:03 AM »
Was many days ago
Can't remember
So, I show test AC Volts, from ground to the 3 wires?
Will do later today
« Last Edit: February 25, 2006, 10:41:03 AM by coldspot »
$0.02
coldspot
Re: CMI PM Motor
« Reply #7 on: February 25, 2006, 10:44:34 AM »
Magnetic center rotor shaft
3 X 4 pc's
Yes magnetic
« Last Edit: February 25, 2006, 10:44:34 AM by coldspot »
$0.02
drdongle
Re: CMI PM Motor
« Reply #8 on: February 25, 2006, 10:46:00 AM »
The model number suggests that it is an ECM ( electronically commutated motor) type which has external 3 phase drive circuitry. If the rotor is not magnetic I'd say that conclusively that it is an ECM unit. If it is magnetic they you should get an AC out put.
« Last Edit: February 25, 2006, 10:46:00 AM by drdongle »
drdongle
Re: CMI PM Motor
« Reply #9 on: February 25, 2006, 10:49:44 AM »
Then treat it as a 3 phase AC alternator and you will take output from the three leads to a 3 phase rectifier. Ground ( green) has no out put connection.
« Last Edit: February 25, 2006, 10:49:44 AM by drdongle »
Re: CMI PM Motor
« Reply #10 on: February 25, 2006, 10:58:21 AM »
agreed.
The fact that different meters show different readings to ground suggests that there may be some electronic device to ground. Winding resistance is probably lower. To prove that it works, just short 2 of the 3 phase wires together and turn it, you will soon know if it is working.
« Last Edit: February 25, 2006, 10:58:21 AM by Flux »
Re: CMI PM Motor
« Reply #11 on: February 25, 2006, 11:27:04 AM »
Set the meter to VAC and test any 2 wires (not to green).
I have a few similar to that.
The magnets are all lame. Like microwave magnet lame.
Mine all started wired star. One or 2 or all would be better wired delta for sure due to low cut in speed.  A good use for the wife's new ceiling fan blades? ;)
I think it'll be great.
« Last Edit: February 25, 2006, 11:27:04 AM by ghurd »
coldspot
Re: CMI PM Motor
« Reply #12 on: February 25, 2006, 11:57:01 AM »
Flux-
Meter readings
Never tested to ground
Ohm's was between wires
red
black
white
There isn't anything inside
Coils, lots of copper
thats all thats inside
All control stripped off
Testing AC Volts
reads overload
Have to try taping together to a small AC motor I got
to get a fixed reading
spinning by hand just overloads then unloads before a reading can be made
Thanks for looking, EveryBODY !!!
« Last Edit: February 25, 2006, 11:57:01 AM by coldspot »
$0.02
coldspot
Re: CMI PM Motor
« Reply #13 on: February 25, 2006, 12:33:38 PM »
OK,
Mounted hub, (5-1/2" pully)
When spun by place-n finger on outer lip
Meter @ VAC setting
Showed 11-12 VAC
Between any set of the three wires.
With having three wires
should I place a fullwave bridge on each or
can a diode, (little black schottky type #SD945)
be put on each wire?
If using a full wave bridge,
(two AC in's w/ Pos/Neg outputs)
I never understand just how to wire them
two of the three to one then
other wire to another, not using the extra
AC input on this one?
Couldn't this "extra" AC input
be hooked to another AC machine?
Or when doing "Bridge Rec's"
wire each wire to bolth AC Inputs
and use one for each wire?
yea crazy I am, BUT
I haven't let any "Magic Smoke"
Out of anything in years, lol!
Darn "Electrical Tech" deg was so many years ago, (21)
Not being in the industry
in anyway, sure lost it all. lol
Might have to fish out the books, (but remember the reading DULL)
« Last Edit: February 25, 2006, 12:33:38 PM by coldspot »
$0.02
Re: CMI PM Motor
« Reply #14 on: February 25, 2006, 12:55:27 PM »
you need a 3 phase bridge, you can't do it half wave without the star point and it is not very clever if you could.
You need six diodes for the 3 phase bridge. Please yourself whether you use 2 single phase bridges or three.
If you use 2, connect dc terminals together + to + and - to -. use 3 of the 4 ac leads and leave one spare or join it to one of the others.
If you use 3 bridges, join dc as before, connect both ac of each bridge to a lead from motor. You now have 12 diodes connected in parallel pairs, works just the same.
« Last Edit: February 25, 2006, 12:55:27 PM by Flux »
coldspot
Re: CMI PM Motor
« Reply #15 on: February 25, 2006, 01:42:01 PM »
SWEET
Thanks Flux
I have been doing it right,
The bridge rec's, just makes
it nice when somebody else
explanes it and you see the light
that was there all along. LOL!
« Last Edit: February 25, 2006, 01:42:01 PM by coldspot »
$0.02
coldspot
Re: CMI PM Motor
« Reply #16 on: February 25, 2006, 05:39:38 PM »
Tested
By strapping tape of tiny little 115V AC motor to
large shaft off CMI unit
Quicky test clipped to a couple little bridge rec's
from computer power supply's
Fluke 23 set on V DC
Computer fan also in loop, (just for fun)
At about 60 RPM, ( I could allmost count it rotating)
24-25 V DC  !!!!!!!
At higher RPM's (little motor would just about get into sync with gen
but tape job sucks from different shaft sizes and gen about 50 times the size it
couldn't quite get there)
BUT, 50+ V DC !!!!!!!!
« Last Edit: February 25, 2006, 05:39:38 PM by coldspot »
$0.02
coldspot
Re: CMI PM Motor
« Reply #17 on: February 25, 2006, 05:45:13 PM »
Trying to keep in sync a bit more,
sad little sucker, (1.3A little motor, hey it hade switched cord
already on it, for easy testin,  lol)
This time it got to much higher RPM'S
I SAW,  112V DC     !!!!!!!!
SWEET
Great day,
Thanks for the help!!!!!
« Last Edit: February 25, 2006, 05:45:13 PM by coldspot »
$0.02
coldspot
Re: CMI PM Motor
« Reply #18 on: February 26, 2006, 12:11:40 PM »
OK, OK
I'm still excited a bit from yesterdays "tests"
BUT,
How many Watts might this get to?
Humm,,,...
P=IV
P=I2R
P=V2/R
No, NO that doesn't seem right?
Lets use 4 Ohm's, (each leg was 3.7,3.9,3.4)
Lets say 25 Vdc, (was at low Rpm)
V=IR
I=V/R
  1. /4=6.250
  2. 250x3=18.750, (three legs)
P=IV
18.750X25=468.750
That seems about there
CMI might be able to get 468 Watts
But as you can see my math skills are slim to say the least
Further testing needed for sure.
Please jump in and fix my math if you know !
« Last Edit: February 26, 2006, 12:11:40 PM by coldspot »
$0.02
coldspot
Re: CMI PM Motor
« Reply #19 on: February 27, 2006, 11:54:27 PM »
CMI-
More testing, hand spinning
by finger against one of ceiling
fan blade holders,(5 blades installed).
OK this baby aint so babyish at 28 Lbs less prop.
But that means lots O Copper!!!
I could get her up to 15 V DC, with one finger. ( no load)
This will need more prop, ceiling fan blades @ 20" + about
5" or so for holder n hub area, with 5 installed
the light winds today, didn't even think about moving it.
O-Well
A tower that tuff is a ways off still anyway.
I'll just keep smiling about the easy higher voltages seen! :)
« Last Edit: February 27, 2006, 11:54:27 PM by coldspot »
$0.02
coldspot
Re: CMI PM Motor
« Reply #20 on: February 28, 2006, 08:47:15 PM »
More test-
Tonight getting my toys from truck
The wind was blowing pretty good,so
I figure, why not just get CMI and blades last.
OK, so I get everything else put away then
I go back out with a little 12 V DC Dash light
and a jumper set, with key and allen wrench.
I set CMI on top of truck Topper shell, wire up
the light, flip the shaft with thumb n finger-
A little bit of a glow in the light, GREAT I think!
So, I mount 5 ceiling fan blade set to the CMI and
grab it to walk out it the more open winds in the
middle of the road, (very seldom used dirt alley type
road out back of house next to train tracks).
I turned the unit into the wind and BOY that was about
the wrong thing to do.
The little 20" blades started spinning and very soon
the little light was VERY bright and I'm thinking about now
HOW do I stop this thing?
Only light out there was from the little light.
Girlfriend was calling me to dinner so I figure
I'll just move finger up to the 5 1/2" pully I
mounted the blades to.
I forgot about the bolts hanging about a 1/3" out
the back/bottom of the pully!
After getting clipped a dozen or so times,
I finally got my fingers to the outside
edge of the pully and slowed it down enough
to turn and yaw it to a stop.
Great test and remembering experience!
« Last Edit: February 28, 2006, 08:47:15 PM by coldspot »
$0.02
Re: CMI PM Motor
« Reply #21 on: March 02, 2006, 08:49:57 AM »
wow i missed this?
« Last Edit: March 02, 2006, 08:49:57 AM by willib »
coldspot
Re: CMI PM Motor
« Reply #22 on: March 08, 2006, 08:26:12 AM »
Hi willib
You didn't miss much just me getting
more stuff closer then switching to
another project.
But this PM motor does make good power.
Testing on a real lathe=
  1. Rpm =  5.6VDC
  2. Rpm = 8.85VDC
  3. Rpm = 13.65VDC
  4. Rpm = 32.9VDC
testing was done unloaded
Only Fluke23 hooked to wires.
RPM's I'm not sure about but the VDC
I was watching and even got a pic or two
The "who has the lathe" said "I think this is"
When he was telling me the RPM's
Also tested a "Treadmill Motor"
(2.5HP, 120VDC, 7100RPM)
  1. Rpm = .55VDC
  2. Rpm = 5.14VDC
This one will need geared up for any usefulness.
But was only $4.00 USD
And I got all electronics out of it
and most of the metal.
(Maybe a good motor for E-Bike, it does have
a good speed controller).
« Last Edit: March 08, 2006, 08:26:12 AM by coldspot »
$0.02
