Author Topic: SinkMaster 401 Turns out to be DC Motor  (Read 1284 times)
coldspot
« on: March 10, 2006, 03:31:55 PM »
The GarbageDisposal Motor turned out to be a DC motor!!! :)
While I'm still trying to get it apart, (Sat unused for many years)
After working it over with a wire brush on the
incoming end, I finally got to see that it wasn't going
to come apart any further there. So tearing back into
Electrical end, I saw that the AC in wires ran into a
VERY tiny little square bridge rec. (Smallest I've ever seen,
this thing could probebly sit on a dime)!!!
IT came apart a bit more to show that it has brushes, and a
two magnet can, (might be multi pole magnets).
A bit more grinding today might show the trick to the teardown,
but I'll post more as info comes up.
« Last Edit: March 10, 2006, 03:31:55 PM by (unknown) »
$0.02
coldspot
Re: SinkMaster 401 Turns out to be DC Motor
« Reply #1 on: March 10, 2006, 06:23:38 PM »
The Incoming end is the end to take apart
when dissambling one of these.
After drilling deep enough into the shaft
the spinning "Cutter" plate did come off to
show that the thing has threads on the shaft.
Now just to spend a few hours hacksawing the
end plate that holds the bushings into something usable.
I did set the Bridge rec on a dime and it's a bit larger than that,
but on a penny, the angled edge and square edges, did fit.
Still didn't test the magnets for multi-pole or single pole yet.
« Last Edit: March 10, 2006, 06:23:38 PM by coldspot »
$0.02
« Reply #2 on: March 12, 2006, 10:25:39 PM »
Hi Coldspot.
This PM motor is the second most common garbage disosal motor. Most common is the AC induction (Garbogen).
The PM motor is very simular to a tredmill motor accept bushings rather then bearing, normaly less HP and a crapy shaft to try to conect anything to.
The small fullwave bridge diode is what I used on my last 8" dual rotor alt. Most of these bridges are rated around 6 amps. I used one bridge per coil. 9X6 for 54 amps of rectifier and there only about 1/2" square. They were also free.
This PM woun't make a very good wind genny but its a good doaner for its curved ceramic magnets. It has 2 magnets, one has N on its face the other has S on its face.
They can be cut, lengthwise will give you 2N and 2S for a smal 4 pole motor conversion. Low power but fun and free.
These would posably make a 4 magnet for a 6 pole 6 slot box fan to 3 phase conversion?
 I soak themn in a can of carboirater cleaner for a few days then gently poe them out.
« Last Edit: March 12, 2006, 10:25:39 PM by Jerry »
coldspot
« Reply #3 on: March 15, 2006, 09:13:56 AM »
Thanks Jerry
Yes it's a bushing motor
Tested with hand drill unloaded
  1. RPM = 11.6VDC
  2. RPM = 46.4VDC
« Last Edit: March 15, 2006, 09:13:56 AM by coldspot »
$0.02
