Author Topic: Building from what you find  (Read 1214 times)
coldspot
« on: April 20, 2006, 02:04:50 AM »
using two Delco fronts and an old motor rotor.
I have the parts to be able to put together
this set-up using stock coils, but seperated
to have the three sets of two wires out.
I've changed the bearings to be able to use
a smaller rotor so I'll be able to put the
magnets on with out any machine work, (other
than maybe screwing down some plastic seperators)
My question is to the number of fields or magnets?
Go with a set number or as many as can fit?
So far I'm into this for the dollar each for bearings
and plan on using old computer power supply's bridge
rec's after running down the pole with wire.
( most tend to be 4-6 Amp at 600-800 volts, so far)
I know rewind would be better but,
I'm still trying to find enough wire for a box fan rewind.
So this one stays stock coils for now.
« Last Edit: April 20, 2006, 02:04:50 AM by (unknown) »
$0.02
Re: Building from what you find
« Reply #1 on: April 19, 2006, 09:05:44 PM »
Hi coldspot ,
dont know about the magnets , but where did you find bearings for a dollar each?
« Last Edit: April 19, 2006, 09:05:44 PM by willib »
« Reply #2 on: April 19, 2006, 09:55:20 PM »
Hi coldspot.
I did 14 magnets cause the GM alt has 14 poles. Count the fingers on the stock rotor. that count equals your magnet count.
A large value cap helps on each fullwave bridge. Try to skew the magnets or cogging will be bad.
Ed has a schimatic of the wireing and coil and cap arangement I think?
« Last Edit: April 19, 2006, 09:55:20 PM by Jerry »
zubbly
« Reply #3 on: April 20, 2006, 04:06:26 AM »
hi coldspot!
many auto alternators are connected delta to begin with from the factory. if yours is, you could connect it star and reach cut in rpm much sooner than you would with delta or individualy rectified phases.
its just a thought.
have fun and let us know how it works out.
zubbly
« Last Edit: April 20, 2006, 04:06:26 AM by zubbly »
coldspot
« Reply #4 on: April 20, 2006, 09:36:11 AM »
willib-
Army store, has a bin full with same OD
but three different ID's.
$0.99 each
The smallest ID ones I've used in the box fan
half inch shaft
This old rotor took the next size up.
probebly not as good as the stock bearings in the delco
But at least it's a standard size.
« Last Edit: April 20, 2006, 09:36:11 AM by coldspot »
$0.02
coldspot
« Reply #5 on: April 20, 2006, 09:51:02 AM »
jerry-
Mr. zubbly-  (Mr in Honor of Bob)
THANKS
This was wired as three out with all three other ends
conected together, I've seperated this so far,
Just another toy for now
I'm sure so far that the best power I'll get
will be from the 28 Lb CMI PM motor, but
I'll have to wait till snow melts to be able
to get up to cabin for a "Real" site n tower
Being in town leaves me with short towers for
testing, one @ 14' and one @ 10', not any real
blade sizes also, (why I'm screwing around with "Trim Blades")
« Last Edit: April 20, 2006, 09:51:02 AM by coldspot »
$0.02
« Reply #6 on: April 20, 2006, 04:39:43 PM »
Thanks ..
Army surplus ?
Army base store?
« Last Edit: April 20, 2006, 04:39:43 PM by willib »
coldspot
« Reply #7 on: April 20, 2006, 05:35:19 PM »
willib-
"Army surplus warehouse"
7012 s. Disney lane
idaho falls
id
83402
« Last Edit: April 20, 2006, 05:35:19 PM by coldspot »
$0.02
coldspot
« Reply #8 on: April 23, 2006, 07:35:42 AM »
Because I don't have any of the
"good" # 29's,   (No money)
And do have a bunch of the
half inch by sixteenth inch N35 disc Neo's
and with the room from using a smaller rotor
I can go with two deep, (stacked on top of each other)
By two or maybe three long, (two fits easly on the lam's
but three would fill the coils insides better).
And needing 14 around, I can only go with one wide,
(11.5" around rotor, minus 7" for the mags leaves
me with .32" spacing between them)
I might follow the skeewing of the lam's on the rotor.
Yesterday I found a short pc of PVC that almost
fits around the rotor. After I cut a section out
for the right width, I'll try to get it to fit over
the rotor with some heat maybe.
(reason for cutting a first test part and
leaving enough to do again with sanding the the ID out a bit)
If this does get to fit over the rotor, I can then drill it
out for a cage to help with magnet placement.
(I've learned about how hard it is to get a magnet to stay
in place while glue slowly dries, and even had them move after
I thought it was dry,{even had some flip over, so paying close
attention to poles is easyer than redoing}).
I also need spacers inside to line up the rotor with the coils,
Has anybody tried using springs for this ???????
« Last Edit: April 23, 2006, 07:35:42 AM by coldspot »
$0.02
