Author Topic: Dish Washer Motor  (Read 1920 times)
coldspot
Dish Washer Motor
« on: May 09, 2006, 03:19:44 AM »
This weekend I found and stripped the motor out of a Old Dish washer
"KitchenAid"
"S62NXHRJ-7199"
Part 242892
"HP 1/2", "115/60/1", "AMP 7.9"
This unit has run and start coils and the run coils are
0.05" or about #15
Start coils look to be about #25
About 2" across the coils
I'd better order some #29's for this one.
From the looks of the run coils this has some real power.
I've done dishes before and remember how hard it was so this
motor was a hard worker before and maybe it will be again in
the better life as a wind gen. lol
« Last Edit: May 09, 2006, 03:19:44 AM by (unknown) »
$0.02
jlt
Re: Dish Washer Motor
« Reply #1 on: May 09, 2006, 05:31:59 AM »
Is there only three wires coming out . you might have to find connection between start and run windings and seperate them . to make two different single phaze windings.I have not done a moter conversion yet but it looks to be easyer than building from scratch.keep us posted. on how it works.jlt inkom id
« Last Edit: May 09, 2006, 05:31:59 AM by jlt »
« Reply #2 on: May 09, 2006, 07:43:39 AM »
Usually the white wire goes to the connection for both coil sets. And yes, its easier.
« Last Edit: May 09, 2006, 07:43:39 AM by ghurd »
coldspot
« Reply #3 on: May 09, 2006, 08:13:22 AM »
ghurd-
jlt-, (would still like that number for the water jet cutter guy, please)
Four wires,
white, red, blue and black
All has innerconection, (continuity)
They have about 13-20 ohms between any two of them using that dam
$225.00 Fluke 23 multimeter
I'll still need to retest with my $4.00, El-cheapO
multimeter, (that seems to work better that the Fluke 23 for this
ohm testing)
What at first I thought was the iner-conection point, turns out to
be the built-in "Thermo-sensor".
White and blue wire running to it.
While this is just a cheap-O motor,
Bushing in rear end but does have a real bearing in front end
and a drilled and tapped shaft for easy hub mounting!
« Last Edit: May 09, 2006, 08:13:22 AM by coldspot »
$0.02
jlt
« Reply #4 on: May 09, 2006, 09:53:25 AM »
re coldspot Pat burrlington 775 3155. Also he may still have the the plans to my 15 inch discs on his machine.. it is 5 hole pattern for a rear hub from 91 buick regal.
« Last Edit: May 09, 2006, 09:53:25 AM by jlt »
jlt
« Reply #5 on: May 09, 2006, 09:58:26 AM »
« Last Edit: May 09, 2006, 09:58:26 AM by jlt »
« Reply #6 on: May 09, 2006, 09:49:56 PM »
With an alias like Coldspot, wouldn't it be more appropriate to pick on a Hotpoint diswasher?  (sorry, I couldn't help it) :^)
« Last Edit: May 09, 2006, 09:49:56 PM by SparWeb »
Warrior
  • Country: ar
« Reply #7 on: May 09, 2006, 10:35:47 PM »
Sorry mate, that looks like a two pole motor. It can work but it is far from ideal. Unless your magnets are really strong and with a small gap, you would need high rpms to get it up to charging speed. Peolpe here have built some conversions with 2 poles but I'd say the minimum to look for is 4 pole.
Good Luck,
Warrior
« Last Edit: May 09, 2006, 10:35:47 PM by Warrior »
commanda
« Reply #8 on: May 09, 2006, 10:48:48 PM »
With the Fluke, you might need to manually set the range rather than letting it autorange. And Fluke aren't the only meters with this problem.
« Last Edit: May 09, 2006, 10:48:48 PM by commanda »
coldspot
« Reply #9 on: May 12, 2006, 08:54:25 AM »
Thanks-
Amanda-
Yea, I know that about the meters,
but was thinking it was the leads on the fluke.
SparWeb-
Good one, LOL !!! :)
Warrior-
You might be right-
Coils do look a bit funny, but just like the size
of the wire!
« Last Edit: May 12, 2006, 08:54:25 AM by coldspot »
$0.02
