Author Topic: Cycle Computer  (Read 1654 times)
coldspot
Cycle Computer
« on: May 14, 2006, 01:04:47 AM »
I finnally found a bicycle computer on sale!  :)
At Walmart $9.95
"Schwinn" sw500
12 function
Or maybe for a wind speed gauge?
Has anybody used this model yet?
« Last Edit: May 14, 2006, 01:04:47 AM by (unknown) »
$0.02
elvin1949
Re: Cycle Computer
« Reply #1 on: May 14, 2006, 01:07:08 AM »
Coldspot
 YES try this.
http://otherpower.com/anemom2.html
Later
Elvin
« Last Edit: May 14, 2006, 01:07:08 AM by elvin1949 »
coldspot
Re: Cycle Computer
« Reply #2 on: May 14, 2006, 04:30:32 AM »
"An Easier Homemade Anemometer"
Yea elvin
Thats the backup plan
using it on the mill is the main plan right now
thanks
« Last Edit: May 14, 2006, 04:30:32 AM by coldspot »
$0.02
snuffy
Re: Cycle Computer
« Reply #3 on: May 16, 2006, 08:33:09 AM »
I built my first anem. with a really cheap bike comp. but found that by the time I had it calibrated the "set" switches had failed.  I ended up getting a $28. one and it works great with the home made easter egg spinner. Worth a try, hope you have better luck than I did. Once it is set up it will probably do fine.
« Last Edit: May 16, 2006, 08:33:09 AM by snuffy »
coldspot
Re: Cycle Computer
« Reply #4 on: May 17, 2006, 02:46:57 PM »
Thanks snuffy-
being a schwinn product
it has a one year warrenty
so hope to be a good choise
I'll build some type of wind speed gauge
out of it I'm sure.
Have a great Day/Night!!!!!
« Last Edit: May 17, 2006, 02:46:57 PM by coldspot »
$0.02
Re: Cycle Computer
« Reply #5 on: May 18, 2006, 12:53:23 PM »
Coldspot,
I'm currently using one like that on mine.  Very useful for doing run-up tests of the alternator on the drill press, and lots more.
The sensor is basically a reed-switch, and when a magnet passes it, the switch closes, sends a pulse to the computer, the computer counts the pulses.  Calibrate the meter with a funny number for "wheel diameter" (can't remember the number, but I can look it up if you want).  Currently the sensor is mounted on the hub bracket, and one of the 1/2" hub bolts has a ring magnet on its tip.  Works great.
The cord between sensor and readout, however, is too short!
« Last Edit: May 18, 2006, 12:53:23 PM by SparWeb »
Re: Cycle Computer
« Reply #6 on: May 28, 2006, 09:31:34 PM »
7 bucks at toys r us
« Last Edit: May 28, 2006, 09:31:34 PM by willib »
coldspot
Re: Cycle Computer
« Reply #7 on: June 25, 2006, 07:26:48 PM »
Steve-
Please look up the number you used
THANK YOU!!!
« Last Edit: June 25, 2006, 07:26:48 PM by coldspot »
$0.02
Re: Cycle Computer
« Reply #8 on: July 04, 2006, 01:08:53 AM »
Coldspot,
Darnit, I can't find that piece of paper.  Starting all over again, I take any old speed as an example:
100 RPM
The sensor is picking up pulses per second and counting them, so:
100 RPM = 1.66667 Hertz
My computer is displaying kilometers per hour, and I want to fool it into reading:
100 kph
convert that into milimeters per second:
100 kph = 277778 mm / sec
Divide the speed by the frequency:
27778 / 1.6667 = 16667 mm
That wheel's a bit bigger than a penny-farthing, so if you can't enter that into your cycle computer's memory, you'll have to settle for 1667, which will give you 10 kph, and it's up to you to multiply by ten.
If your computer works in MPH, then you need 26822.
« Last Edit: July 04, 2006, 01:08:53 AM by SparWeb »
