Author Topic: MPH from an old workout type bike maybe  (Read 983 times)
coldspot
« on: July 12, 2006, 01:19:54 AM »
Was over at Aunts house the other week and while telling her
how to catch the people that are helping themselfs to her flowers.
(security cameras, I play with and have what some say is WAY to many of), LOL
I spotted sitting by her trash cans,
An Exersize bike. She told me it was GrandMa's old one and had bad bearings in the crank so the chain wouldn't stay on it.
She said to take it if I wanted and even helped load it up for me.
I left it in truck under the shell so girlfriend wouldn't say something
about my junk collection,. lol.
But had to pull it out the other night so I could go load up an old desk
I saw behind the U-Haul that I'll be using for battery bank box.
So while it's now were I can look it over better, I checked the battery's in the
little speed-o thingy and to my surprise they hadn't leaked yet so I pulled
this off and apart but couldn't get the end off at the wheel. (later it came apart)
So I look over the bike and see broken welds holding the crank to the frame.
This is what I thought had been the problem so I desided to strip it down for parts.
The speed-o is a reed type switch I found out and the unit works with new batteries.
This set-up could be used easly for a windmill or anometer, and will have cheaper batteries than a bike computer type, (2- AA's)
It's off a "LifeStyler" brand so old I can't even guess at. ( 80's maybe even 70's)
I'm going to use it down the road and will post more then.
The other parts are great and I might even try the seat on my mountian bike
because I'm sure anything would be better than what it's got now. LOL
« Last Edit: July 12, 2006, 01:19:54 AM by (unknown) »
$0.02
Re: MPH from an old workout type bike maybe
« Reply #1 on: July 11, 2006, 09:14:00 PM »
Before you go climbing your tower to mount a magnet and reed switch, try this:
 - NPN switching transistor
 - Emitter to one phase of your genny.
 - Resistor from base to another phase.
 - Measure voltage across the reed switch wires and connect:
    - Positive one to the collector.
    - Negative one to the emitter/phase junction.
 - 1N4004 band to collector, non-band to emitter (to protect the speedo if something goes funky and genny voltage appears at the collector.)
It may read some hysterical speed, top out, and be useless.  But if it works out it will save you a lot of climbing.  B-)
« Last Edit: July 11, 2006, 09:14:00 PM by Ungrounded Lightning Rod »
coldspot
« Reply #3 on: July 12, 2006, 05:46:46 AM »
ULR-
Woof-
"climbing your tower"
Thats still only a dream, for me that is. lol
Test tower # 1 @ 13'
#2 @ 15'
Anemometer tower @ 20'   lol  :)
I've built a bike computer/Host cup n hub
It's on taller tower!!!
Had to use the # 1320 as starting point when calibrating it and am still trying
to get it down to really perfect MPH but very happy with it so far.
This unit from exersize bike just is about the same size as the cup-n-hub to
start with. Also has no settings to adjust.
Really like the cheaper batteries, two AA's it uses.
The digital read out is about the size but whole unit much larger than
wrist-watch sized bike unit.
This one also was mounted on the wheel shaft not farther from center like
modern bike computers.
I'll probebly make an extra anemometer out of it.
I've noticed that some newer mini-weather station units along side the road are
using a hawt not the standard vwat on them around here. ??????
A builder could also add a mini-mag to alt's n gen's and use just about
magnet type switch and just also run some phone line down to be able to
check RPM's or MPH by just hooking up to line when wanted. This is only
a just out of bed thought as of now and I've still not tested the window
alarm sensors I've saved from remodel's in the past.
(having one of those mornings that a crazy windmill stuff dream woke me up early) LOL!
THANKS
Have a great DAY!!!!!!
« Last Edit: July 12, 2006, 05:46:46 AM by coldspot »
$0.02
coldspot
« Reply #4 on: July 13, 2006, 06:17:25 AM »
"try the seat on my mountian bike"
That was a really bad idea!!!!!
While just sitting or even riding normally around this is ok as a seat,
I forgot about how, that when you are riding around on a bike and have to
go under low tree branchs you have to not just duck down but slide off
the seat backwards to get under the really low ones and of course
found out the hard way. OUCH !!!!!   lol
« Last Edit: July 13, 2006, 06:17:25 AM by coldspot »
$0.02
