Author Topic: mini motor conversion finished  (Read 7290 times)
Re: mini motor conversion finished
« Reply #33 on: August 14, 2006, 08:15:27 PM »
Something must have gone really wrong when I measured power first time.
Just measured again, using a lamp as a load.
at 600RPM, it sees 18VAC at 85mA.
18 * .085 = 1.53W
When the stator losses are .45W, this means that .45/1.53 * 100% = 29% are stator losses. This is much more than the original 10%...
What I suspected was correct: my original powermeasurement was not good enough.
30% is a lot; hopefully it will be less for the full size conversions (130W & 3hp).
« Last Edit: August 14, 2006, 08:15:27 PM by dinges »
« Reply #34 on: August 15, 2006, 05:56:19 AM »
It is early here Peter, but what about the (lack of) efficiency of the motor?
With 300 ohm coils X 85ma = 25.5V.  2.17W or 59% is lost in the coils.
Plus 1.53W output = 3.7W.
That takes stator losses back down to 12%.  Right?
« Last Edit: August 15, 2006, 05:56:19 AM by ghurd »
« Reply #35 on: August 15, 2006, 04:37:20 PM »
What can I say; it was late over here...
« Last Edit: August 15, 2006, 04:37:20 PM by dinges »
« Reply #36 on: August 16, 2006, 04:29:47 AM »
In defense of Henkel (mfg. of Loctite),
They did respond to my question, though a bit late (2 weeks). For bonding nickel plated magnets to steel, they recommend Loctite 326.
I used epoxy and will continue to use that, but it may be relevant information for others.
« Last Edit: August 16, 2006, 04:29:47 AM by dinges »
« Reply #37 on: August 23, 2006, 01:32:29 PM »
Glenn,
I've made a mistaken, I realize now. I've distributed 42 magnets over the circumference, it should have been 56.
Hope this explanation on how to de-cog was clear enough.
Grtz.
« Last Edit: August 23, 2006, 01:32:29 PM by dinges »
