Author Topic: Edison Batterys  (Read 3448 times)
coldspot
Edison Batterys
« on: September 01, 2006, 07:10:40 PM »
I picked up a battery bank last weekend
Edison Batterys
Cell type
A6H
Amperes Normal Charge and Discharge rate = 45
Ampere Hour Capacity Normal rate = 225
I got 12 sets of cells
two per set
Anybody out know how to get the age off the serial numbers??????
« Last Edit: September 01, 2006, 07:10:40 PM by (unknown) »
$0.02
Re: Edison Batterys
« Reply #1 on: September 01, 2006, 04:25:07 PM »
WOW!!
If I could say that larger I would say like 3 times as large WOW!
"Edison Batterys"
If you find they work well and are from like 1930 or so I will trade you my house for them :)
 1960 or so I'll trade car.
Just joking, or am I?
Where did you find such and are there more. I don't really know how good it would to be to have such batteries but I been dying to get some anyway just to test out myself.
Great find you lucky devil!!!
« Last Edit: September 01, 2006, 04:25:07 PM by nothing to lose »
coldspot
Re: Edison Batterys
« Reply #2 on: September 01, 2006, 05:53:50 PM »
nothing to lose-
But,
Wait till you see this-
"Best",
Brand Inverter
  1. -38 VDC Input
  2. VAC regulated output, 60 Hz
Watts= 3000 maximum continuous load
Watts Surge Load= 12,000 WATTS!!!!!!!
Nominal Battery Voltage= 32 VDC
This thing weights 75Lbs!!!
« Last Edit: September 01, 2006, 05:53:50 PM by coldspot »
$0.02
inode buddha
Re: Edison Batterys
« Reply #3 on: September 01, 2006, 07:58:00 PM »
FWIW I have the original recipt for the bill from when my great-grandparents got electricity in the 1930's. Total 50 bucks, which included the electrician wiring everything (three light bulbs and two outlets).
It was a 36-volt system with a Wincharger and unspecified batteries.
I bet you could restore or save these batteries of yours; outlying areas of the telephone company might have a few or have the know-how. They used to use them to power the phone system when the mains power went down. I would ask Ma Bell for an older tech/maintenance guy, they might know.
« Last Edit: September 01, 2006, 07:58:00 PM by inode buddha »
Re: Edison Batterys
« Reply #4 on: September 01, 2006, 08:06:42 PM »
what does that say under storage battery?
« Last Edit: September 01, 2006, 08:06:42 PM by willib »
elvin1949
Re: Edison Batterys
« Reply #5 on: September 02, 2006, 12:56:37 AM »
Coldspot
 Last year someone on here scanned in a owner's
manual for these batteries.seem's like you can bring them back to life even after year's of sitting discharged.I can't find it right now BUT i am sure
it is here on this board.
 I did make a copy [print and cd].It will take a while to find that-remodeling nothing is where it is supposed to be.If i find it i will post it.
 Read about one of these batteries 90 yr's old and still working.
elvin
« Last Edit: September 02, 2006, 12:56:37 AM by elvin1949 »
elvin1949
Re: Edison Batterys
« Reply #6 on: September 02, 2006, 01:55:19 AM »
Found it,Thunderhead put it up last june.
http://home.cybertron.com/~edurand/Otherstuff/Edison.html
elvin
« Last Edit: September 02, 2006, 01:55:19 AM by elvin1949 »
jlt
Re: Edison Batterys
« Reply #7 on: September 02, 2006, 06:44:04 AM »
I would try to put 9 cell in a bank and charge them up to about 16.5 volts. and then discharge them at 20 amps. until they show 6volts on the bank of 9 and then write down volts on each cell. that should weed out the weak ones.you may have to repeat this 2 or 3 times.(jlt inkom idaho}
« Last Edit: September 02, 2006, 06:44:04 AM by jlt »
Re: Edison Batterys
« Reply #8 on: September 02, 2006, 08:18:40 AM »
Wow nice!
  1. amps normal charge and discharge rate
  2. hours capacity at normal charge/discharge rate
pretty awesome
it seems you cant kill these things , if something happens to them , just take them apart clean them and put in new solution.
they even recommend overcharging them
till they start frothing , at which time you should stop charging. lol
« Last Edit: September 02, 2006, 08:18:40 AM by willib »
Re: Edison Batterys
« Reply #9 on: September 02, 2006, 08:20:26 AM »
second mumber = 225
thanks scoop
« Last Edit: September 02, 2006, 08:20:26 AM by willib »
coldspot
Re: Edison Batterys
« Reply #10 on: September 05, 2006, 01:15:24 PM »
willib-
"Do not use Acid in this Battery"
« Last Edit: September 05, 2006, 01:15:24 PM by coldspot »
$0.02
coldspot
Re: Edison Batterys
« Reply #11 on: September 05, 2006, 01:18:38 PM »
elvin-
Yes,
I've seen, copied, read and re-read
this many times
Thats were I got the info on
"A6H" cells
When I first got one cleaned up enough
to see the marking
"A6H"
I was pretty bummed-
Thinking only 6 Amp hours for all this work-
Then I researched this and found that it's
225 Ah
« Last Edit: September 05, 2006, 01:18:38 PM by coldspot »
$0.02
coldspot
Re: Edison Batterys
« Reply #12 on: September 05, 2006, 08:51:04 PM »
While researching these batteries-
"Edison's batteries were made from about 1903 to 1940."
I'm still trying to find the age of these
"A6H" Cells
They all have serial numbers and the sealing lids
on them have "McGraw Edison" on them,??????
Maybe the lids are an after market type thing
sold by the company that bought the "Edison Co."
The crusty's on the tops are chipping off nicely, slowly
But it's an after work thing.
I haven't even gotten one all the way open yet to check
fluid level and add Disstilled water.
Maybe later or tomorrow.
l8r
THANKS
« Last Edit: September 05, 2006, 08:51:04 PM by coldspot »
$0.02
coldspot
Re: Edison Batterys
« Reply #13 on: September 06, 2006, 01:53:31 AM »
Still researching-
I read something that makes me worry a bit-
Bruce s
posted in a post about niCads
"The one thing you'll not want to do it let them go below 1.01Vdc/cell. AT this point NiCds begin to reverse polarity internally and are subject to bursting if you try to recover them ( happen in our shop more than once)."
I was writing down all the serial numbers and what the voltage is
of each pack or each cell today and
I found some that are,
"reverse polarity",
I'm talking about a few hundreds, (-0.0#)
Am I going to have a few burstings of my own??????????????
That would make girlfriend very un-Happy,
heck, I can't even bring these into backyard, they are sitting,
hidden out back between my truck and fence.
I've sort of covered them up with a wood pile.
The things I get myself into trying to learn RE and build something useful.
« Last Edit: September 06, 2006, 01:53:31 AM by coldspot »
$0.02
elvin1949
Re: Edison Batterys
« Reply #14 on: September 07, 2006, 06:49:23 PM »
ColdSpot
 Got yourself a goldmine there,Will be glad when it is all rebuilt and flying.
 Keep us posted.
elvin
« Last Edit: September 07, 2006, 06:49:23 PM by elvin1949 »
elvin1949
Re: Edison Batterys
« Reply #15 on: September 07, 2006, 06:53:47 PM »
 No these won't burst.Bruce is dealing with sealed ni-cad's.Your's are flooded NiFe.
elvin
« Last Edit: September 07, 2006, 06:53:47 PM by elvin1949 »
coldspot
Re: Edison Batterys
« Reply #16 on: September 07, 2006, 09:33:44 PM »
Researching-
In my notes on NIFe,
"Chevron" "Utility Oil 22"
ONLY!
Well so far, It's sold in a 55 Gal drum,
ONLY!
Only other web result besides otherpower,
Is a distributor in Salt Lake City Utah.
(About 3 hours from me)
55 Gal size only listing.
I'll have to E-mail and or call them and see about a qt or pt size.
Unless I wanted to go E-baying for a full
"Edison Battery Oil Bottle"
LOL
Yea Right!
« Last Edit: September 07, 2006, 09:33:44 PM by coldspot »
$0.02
