Author Topic: Wind  (Read 915 times)
bj
Wind
« on: December 13, 2006, 04:12:10 PM »
   So the new try, again a modified g.m. puts out what I expected.
Am happy, so far with output, but came up with a question, while
working on the test bench, on the next one.
   The question being--on any P.M. is the open circuit cogging
equal to losses in the P.M.  As in flux losses etc.  I suspect so,
as I can't see any other reason, but I have been dumb before.
   Only reason for the question, is, that if this is true, I can
concentrate on the magnetic portion of the P.M. while still on the
bench.  I am happy with the Neo's, windings, etc. am just trying
to improve efficiency with less losses.  The cogging is not large,
and I am sure there are no internal shorts, etc.  Have tried the same
P.M's with no diodes, and cogging is the same, or very close.
   Anyway, just trying to see if I am missing something obvious.
   bj
« Last Edit: December 13, 2006, 04:12:10 PM by (unknown) »
bj
Lamont AB Can.
RP
Re: Wind
« Reply #1 on: December 13, 2006, 09:11:40 PM »
No, cogging isn't really a loss.  The energy it takes to get the half way point is pretty much given back when the rotor "snaps" to the next postion.  It's just that it take a certain amount of energy to get it started.
If you attach a heavy flywheel and get it turning at a moderate rate you'll find it really doesn't take much force to keep it turning.  In this case the flywheel stores the energy form the snap and gives back to push past the next cog.
« Last Edit: December 13, 2006, 09:11:40 PM by RP »
bj
Re: Wind
« Reply #2 on: December 22, 2006, 04:28:28 PM »
    RP
    With a nudge from you, that makes sense.  Guess I was looking for
a simple way, which there isn't.
    thanks
    bj
« Last Edit: December 22, 2006, 04:28:28 PM by bj »
bj
Lamont AB Can.
