Author Topic: to much wind.......  (Read 819 times)
to much wind.......
« on: January 17, 2007, 12:41:23 AM »
just a news artical from the daily rag...
                   http://www.adn.com/news/alaska/rural/story/8565548p-8459152c.html
« Last Edit: January 17, 2007, 12:41:23 AM by (unknown) »
Gordy
Re: to much wind.......
« Reply #1 on: January 16, 2007, 10:53:45 PM »
Hiker,
Sounds like a good place for the slower turning savoirnous mill's. I would also think they would be better off going with multable smaller units instead of one BIG one. Both for redundancy, if one or two were to break, and I think less forces exerted on the smaller mills. But would still be a chalange to beef them up to that kind of force's.
Maybe the Dan's could design something for them, after all they have helped lots of people start makeing power now in low winds that the "experts" say isn't worth messing with ;)
Gordy
« Last Edit: January 16, 2007, 10:53:45 PM by Gordy »
Nando
« Reply #2 on: January 17, 2007, 08:47:19 AM »
For this type of wind, the PITCH controlled wind mill is a good try, specially making the generator with excess power.
The blades profile convoluted to present a negative profile to assist in the RPM control setting angle.
A major problem is the tower support that have to be stiffened and cabling if any, set to work with such cold environment.
The Hub of the mill may need part of the generator engine to keep the hub warm for easy self control, or an additional secondary generator feeding the hub heaters, and the hub needs insulation for momentary temperature protection.
The design needs to take in account the high gusts which means the size (length) of the blades have to be reduced or minimized with a specialized profile.
Also, it may be that a Vertical may be best for that place, though good site evaluation is needed by people with "long" active experience with wind, & low temperatures with knowledge in metallurgy low temperature behavior.
Nando
« Last Edit: January 17, 2007, 08:47:19 AM by Nando »
