Author Topic: Diaries  (Read 1235 times)
bj
Diaries
« on: January 18, 2007, 03:45:35 AM »
     SO new P.M was up, and put out expected watts.  For a couple of
days.  Then we had this WIND.  Published speeds were 90 kph.  O.K.
I've seen that.  Anyway, as Flux said, resistance loads, like lights, or heaters, decrease draw with temperature.  But my load, a big 1500 heater
would be enough, I hope.  Wrong.
     At 11:00 I knew I had trouble.  Blinding snowstorm, But I have a
rope to the shop for these storms.  Genny is going nuts.  Resistant
load #1 is burnt.  Out comes the 1500 watt heater.  Hooked up, Not
much change in rpm.  So waited for a calm, and tried shorting it out.
    Big arc, but not a bit of slowdown.  Gave up, as I was very cold,
and the blades are supposed to keep up with 160 kpm winds, as long as
they are spinning.  And they were spinning.
     So to bed.  About three in the morning, I noticed a change in the
sound, then all was quiet.  In the morning, what I saw was interesting.
     Top tower mount was torn out, and tower had folded.  All is sitting
on the roof, but blades and genny are fine.  Looks like the tower folded
slow enough for the blades to slow down.  Tower, don't care.  Experimental only.  What the blades endured is, at the least interesting.
     Pheonix will be better.
     It has been fun.  Learning is fun.
     bj
« Last Edit: January 18, 2007, 03:45:35 AM by (unknown) »
bj
Lamont AB Can.
RP
Re: Diaries
« Reply #1 on: January 17, 2007, 09:20:57 PM »
Sorry to hear it bj.
As to the slow folding of the tower, I've often thought that the gyroscopic forces from the spinning blades would tend to slow the falling motion from a guy wire break.  Perhaps that played a role in this too.
« Last Edit: January 17, 2007, 09:20:57 PM by RP »
coldspot
Re: Diaries
« Reply #2 on: January 18, 2007, 11:47:57 AM »
Bummer deal !!!!
I'm sorry to hear about that.
But would like to know more for "Learning Fun".
Like what was tower made from and guy system used?
And pictures are always good.
I hate to hear about these things but I also think we all are learning to build them better as we hear about them going down.
« Last Edit: January 18, 2007, 11:47:57 AM by coldspot »
$0.02
Re: Diaries
« Reply #3 on: January 18, 2007, 03:55:50 PM »
Bj got your email and pic thanks.Thats one awesome eggbeater turbine.
 You guys really got it cold there could that be weakening things?Hang in there and sorry for the loss.
 Has far has pics go i think there might be free stuff out there to help size pics to post here.My cheapie camera came with this Photoimpression software that you can set the size to 480X640 then jpg tag the file.Im getting a slight grip on this stuff.
 p.s.The pic was huge.but if you can figure out how to upload them, guys here could help.
« Last Edit: January 18, 2007, 03:55:50 PM by vawtman »
wil
Re: Diaries
« Reply #4 on: January 18, 2007, 08:29:26 PM »
Someone here suggested IrFanView to resize pictures, I can say from experience it's easy to use and works very well.
Wil
« Last Edit: January 18, 2007, 08:29:26 PM by wil »
coldspot
Re: Diaries
« Reply #5 on: January 20, 2007, 03:41:34 AM »
Yes
Irfanview
free download
easy as pie to use
just wrong click,(the right mouse button)the pic
pick open with irfanview,(best to make a new folder first with pictures named resized)
once open on top tool bar click image, then about half way down click resize/resample, then type in new size, i use 300 as first number 2nd number is auto after that, that gets mine down below the size wanted here but you'll have to test and it shows the kb after you pick size.
I then reclick image and towards bottom I click sharpen for better pic's
then click the little a-drive disc looking image at top and then save in the right folder
it's best to name pic's first then you'll be able to know whats what when looking later like here at your images uploaded without seeing as thumbnails
just my
$0.02
« Last Edit: January 20, 2007, 03:41:34 AM by coldspot »
$0.02
bj
Re: Diaries
« Reply #6 on: January 22, 2007, 06:25:20 AM »
     Your .02 might be worth much more. downloaded this morn.
Takes a lot of time on a dialup.  If works, will post.
     bj
« Last Edit: January 22, 2007, 06:25:20 AM by bj »
bj
Lamont AB Can.
bj
Re: Diaries
« Reply #7 on: January 22, 2007, 06:41:37 AM »
    Vawtman:  Sorry for the size, but wanted to give as much
detail as possible.  If, after going through all the varous
checks, as I do do,  before I send, you save to a file, then
the file is more friendly.  Size is automatically adjustded
resized to screen size.
     And yes, cold may have played a role.  Have seen winds
this strong, and no problems.   So, cold has a definite effect
on steel.  But, again, no real loss.  Just an experiment.
    The pics were just to show you that someone thinks
that vawt's are great, and is willing to put money where
their mouth is.
    Keep trying.
    bj
« Last Edit: January 22, 2007, 06:41:37 AM by bj »
bj
Lamont AB Can.
bj
Re: Diaries
« Reply #8 on: January 22, 2007, 06:52:41 AM »
    Hadn't thought of gyro forces.  But your thought makes sense.
Something made the blades stop before they hit the roof.  As load
was gone, Gyro makes sense.  THANKS.  That is why this board
is so great, as the single mind can't do everything. Although, some
do better than mine.
    bj
« Last Edit: January 22, 2007, 06:52:41 AM by bj »
bj
Lamont AB Can.
bj
Re: Diaries
« Reply #9 on: January 22, 2007, 07:15:09 AM »
   cold---- thanks, but is not a big loss.  Tower was just a test
tower, so, no real loss.  And have ten more sections, so loss
isn't so much.  Loss was due to poor connectionns at the top.
    Single connections won't work in strongh winds.  Next time
will be smarter.
   bj
« Last Edit: January 22, 2007, 07:15:09 AM by bj »
bj
Lamont AB Can.
bj
Re: Diaries Thanks To All
« Reply #10 on: April 10, 2007, 01:50:48 PM »
    Been gone for a while, as hard drive has gone to a better place.
Been lots of good comments while I was away, and thanks to all.
    Genny is in the shop, is alive, but one blade is bent from pressing on the roof.  A short test with a heat lamp, with the blades level to
the floor, reduced the bend from 8 inches, to two. It will heal. I think.
    Contrary to previous post, the blades were still turning when they
hit the roof.  Tracks in the galvanized roofing told the tale.  Tough
material, as I can't find any impact damage on the blades.  Only a
strong wind will tell, I guess.
    Won't give up.
    Again, thanks to all
    bj
« Last Edit: April 10, 2007, 01:50:48 PM by bj »
bj
Lamont AB Can.
