Author Topic: Stacker update  (Read 1052 times)
Stacker update
« on: February 17, 2007, 10:42:25 PM »
I got around to adding a third coil  to the  jig  .I offset the coils by 3 and 6 degrees .Looks like there's a slight difference in the width of the rise from zero ( stacked in line series ) . Am  finishing  out the stator at three degrees center coil and 6 degree outside sacrificing some peck to peck voltage for duration  . Pdf links for 0,3,6,7, degrees .
http://www.otherpower.com/images/scimages/1431/0de_2v.pdf
http://www.otherpower.com/images/scimages/1431/3de_2v.pdf
http://www.otherpower.com/images/scimages/1431/6de_2v.pdf
http://www.otherpower.com/images/scimages/1431/7de_2v.pdf
« Last Edit: February 17, 2007, 10:42:25 PM by (unknown) »
Nando
Re: Stacker update
« Reply #1 on: February 17, 2007, 08:45:09 PM »
Tecker:
Can you detail the software you use for the measurements that you have displayed on the PC.
Nando
« Last Edit: February 17, 2007, 08:45:09 PM by Nando »
Re: Stacker update
« Reply #2 on: February 17, 2007, 09:52:44 PM »
 Tip 440 scope meter software version 4.43
« Last Edit: February 17, 2007, 09:52:44 PM by tecker »
Re: Stacker update
« Reply #3 on: February 18, 2007, 10:21:24 AM »
 The measurements were made on three 25 turn coils offset in series.Somewhat simular to
a single coil with wide legs at 75 turns. Mags are 1/2 X 1.5 x 1/2
« Last Edit: February 18, 2007, 10:21:24 AM by tecker »
