Author Topic: Bicycle dynamo hub Powering CFL directly  (Read 2822 times)
gotwind2
  • ben[at]gotwind.org
« on: February 24, 2007, 04:48:04 PM »
I was surprised to see that one of my 12v 5W AC bicycle dynamo hubs (rectified) powered an 11 watt 12 volt compact fluorescent lamp! - I didn't think it would.
The lamps must be able to illuminate at much lower power levels, than rated?
Also do cfls tolerate being switched on and off regularly? like L.E.D's.
You Tube video of it here.
http://www.youtube.com/watch?v=hDpNE1IMEA4
« Last Edit: February 24, 2007, 04:48:04 PM by (unknown) »
Re: Bicycle dynamo hub Powering CFL directly
« Reply #1 on: February 25, 2007, 09:34:38 AM »
Have you ever considered using a super cap?
Something like this?
http://www.los-gatos.ca.us/davidbu/pedgen/ultimate_pedal_tv.html
Not near as large ...but just large enough to
smooth out the voltage.
CFLs don't seem to tolerate on and off near as
well as LEDs
       ( :>) Norm
« Last Edit: February 25, 2007, 09:34:38 AM by Norm »
gotwind2
« Reply #2 on: February 25, 2007, 11:52:59 AM »
Hi Norm,
No I have not considered using a super capacitor, electronics is not really my strong point.
Would I be right in connecting a capacitor across the positive and negative DC feed?
It was really just an interesting demonstration of just how little power is needed to make the equivalent of 60 watts (incandescent bulb.)
Ben
« Last Edit: February 25, 2007, 11:52:59 AM by gotwind2 »
alancorey
« Reply #3 on: February 27, 2007, 11:29:28 AM »
I have a 5 watt 12 volt that I bought on eBay.  Actually it's a replacement.  The first one stopped working after less than 1/2 hour of use.  The seller replaced it free, but said they were sensitive to low voltage, noise on the power line, bad connections, etc.  I think he was just making excuses, but I don't really trust the replacement much.  The original had never been mistreated in any of these ways.  I had just rigged up a light socket rubber-banded to the top of a SLA, and was only beginning to decide how I was going to use it.  I had crimped push-on connectors for the SLA, wires under tight screws on the light socket and everything instead of the alligator clips I had been using.  That's when it blew.
I've got the replacement in a ceiling-mouted 12 volt socket, and used it less than 5 minutes.  Mine was actually consuming more like 7 watts by my ammeter, but I figured the 5 watts was what the bulb takes, not counting the efficiency of the inverter built into the base.
The one I've got is probably cheap junk, but I wouldn't consider them very durable.
Nice finding with the DynoHub, but the CFL probably prefers cleaner, more constant power.
  Alan
« Last Edit: February 27, 2007, 11:29:28 AM by alancorey »
