Author Topic: Stepper Motor Minimill  (Read 2603 times)
RogerAS
« on: April 27, 2007, 01:12:54 AM »
Greetings All,
Thanks to Pepa for the digital camera, and a few spare minutes from one hectic spring, I am presenting my larger and improved stepper motor minimill. There are 2 of these up and spinning, when the wind gods smile. I have one more yet to build.
An old dead VCR provided the mount for the motor to base and motor shaft to blades. I just shot drywall screws through the VCR motor part disc into the blades. You will notice a couple dabs of JB Weld here and there to lock things down. The part the mounts the VCR motor to the frame of the VCR was used, after modification, to screw the motor to the wood mounting plate. I had to cut away some of the VCR mount for clearance, but otherwise was a good fit.
The blades are jigsaw cut from a plastic 55 GAL drum, then propane torch heated and twisted. I held them in position until cool and they retained the shape pretty well. They are 15" long by 3" at the root each. Blancing was fairly easy.
I series matched the 4 output leads and turned it into a single phase, and the rectifier from the VCR power supply is seen in photo 1 to the right, mounted on a small aluminum heatsimk. My past steppers, much much smaller motors, I rectified each phase and drove them with box fan blades, seen in the background of picture 2. These 2 "new" stepper mills put out much more than the old versions and now none of them are flying. I also did away with the capacitors as these motors, 15V IBM 4 lead motors, come up to 12V~ charging voltage quite easily. These were salvaged from laser printers found at the local landfill.
So aside from time I have about $2 each in these machines and in a really stiff wind will produce about 2 amps each. In single phase they do hum real loud when cranking. I plan on experimenting with furling when I get more time, but as they are now they do not.
Having too much fun!
« Last Edit: April 27, 2007, 01:12:54 AM by (unknown) »
pepa
Re: Stepper Motor Minimill
« Reply #1 on: April 26, 2007, 08:48:55 PM »
very good Rodger, pretty soon you will have a whole wind farm on the side of that mountain, keep up the good work. pepa
« Last Edit: April 26, 2007, 08:48:55 PM by pepa »
« Reply #2 on: April 29, 2007, 12:50:44 PM »
You wouldn't have the numbers from that motor handy?
Half amp sounds great.
« Last Edit: April 29, 2007, 12:50:44 PM by ghurd »
RogerAS
« Reply #3 on: April 30, 2007, 05:34:10 AM »
Ghurd,
No I don't. All the motors came from the same model and brand of IBM laser printers, but only one had the sticker left readable. That's the one I put together first and it has a weather cover on it. I will take that cover off later today and see if the info is still readable on it.
These motors have 4 lead wires, and rated at 15V. I do remember that much.
Look for a followup later today.
« Last Edit: April 30, 2007, 05:34:10 AM by RogerAS »
RogerAS
« Reply #4 on: April 30, 2007, 07:45:17 AM »
Ghurd,
Well I went out and dropped the mill that HAD the nameplate intact. HAD is the keyword here as vibration has eaten into the label a bit. The label is a paper based sticker. My mounting method had the label resting down against the base plate, sorry.
I was mistaken about the IBM part. The motor can is 2.25" in diameter and 1.625" deep with equal shaft extensions of 1.25" with a .25" diameter. Apprently these are NEMA 34 motors. While removed from IBM equipment these are Applied Motion Technologies motors and a google search was useless, must be obsolete part. The parts of the label I can still read are as follows:
.95 amps per phase (X2). Impedance Protected (whatever that means). 15V.
(these numbers are erroded at the beginning and are not be complete)
  ?023-200-024PF
  5023-861 (3T-95) (apparent model number)
  60033-2
Sorry for the lack of useful info!
« Last Edit: April 30, 2007, 07:45:17 AM by RogerAS »
« Reply #5 on: April 30, 2007, 08:18:13 AM »
Still good info!  Thanks.
I still watch for free and easy to get steppers, but gave up buying them for windmills.
I have a 24V 8-wire(?) IBM. It makes well over 100VAC by hand. Painful, but almost no ma. :-(
Impedance Protected means the resistance is so high it just about can't burn itself up.
« Last Edit: April 30, 2007, 08:18:13 AM by ghurd »
