Author Topic: Idea forget mppt and get more stored power.  (Read 1269 times)
terramir
« on: May 28, 2007, 04:58:00 AM »
I just got an idea from a very another group, (man this guy didn't have a clue), but it gave me an idea a wicked one at that.
Li-ion's have a tendency to gobble up all the current they can get until they are about 70% full, reaching max voltage usually 4.2V per cell. then most chargers then switch to a constant voltage and let the cells eat whatever current they like which starts being less and less near full charge (full charge .03 of C in A).
Now the li-ion chemistry will also let you charge them to 4.05V per cell or even less and then start taking constant voltage and the current will follow the same curve as well as if you had charges it to 4.2V and then switched to constant voltage. 4.05V will conserve cell life BTW harmful reactions (to the cell life) Start over 4.05V.
Now 12V solar panels tend to have a mpp of around 17V add a diode and you got 16.2V-16.5V. Over this voltage the current delivered by the solar panel will drop dramatically, Now once a bank of four cells (or multiple banks of fours) reaches 16.2V it will attempt to rise higher, but since the current will drop-off so will the charging voltage (now this will only work if the li-ion bank size is several times the capacity in C of the max current of your solar array. If you put a simple monitor that will cut off the power if a cell reaches 4.2V (max safe voltage) or total 16.8V the cells which are not fully charges will drop back down to around 4.05V per cell total 16.2 V which is your diode modified MPP. If you have a bank that is 10X greater in C than the max current of your array I doubt that the voltage will even rise past the MPP until the cells are as full as they will get at a 4.05V charging curve which is an estimated 85% of C. (Mind you if you go the 4.05/cell route even if the voltage then rises at reduced current you will only get like 86% to 90% of capacity of the cell max.)
This would have 2 advantages
#1 it would be safe as long as two conditions are met (maximum cut-off 16.8V) and a modified MPP around 16.2V (A regular diode should do the trick as long as you don't make that diodes capacity too big - higher capacity less voltage drop :S) A safety temp cut-off would be a bonus)
#2 since the voltage from the get-go is higher you would get more power out of your panels since 80% of the discharge power is above 3.5V in graphite based cells(most cells these days are graphite based) 60% in coke but until 80% even coke will stay over 3V so even if you discharged your bank by 60% you'd have a starting charge voltage of 14V. Lead acids discharged by 40% drop down to like below 12V.
So if you had 6A of charging current that would be an additional 12 Wh  well you can do the math.
Question: what do you guys think? Viable? Take a close look at mmp curves.
And also another thought If you have to deal with depressions in the mmp due to temperature a latching relay system that puts the power through diodes with different voltage drops may be the solution. Should be simple with a temperature probe circuit.
« Last Edit: May 28, 2007, 04:58:00 AM by (unknown) »
jimovonz
Re: Idea forget mppt and get more stored power.
« Reply #1 on: May 29, 2007, 03:04:47 PM »
I am not sure I understand you. Are you suggesting using 4 x ~4V cells for a 16V nominal battery to get closer to the MPP? If so then I don't think you would be doing yourself any favours implementing such a system. There is a reason that PV panels are designed with a higher max voltage than the nominal rating. The output voltage of a panel varies considerably depending on insolation/temp. The MPP may be ~17V at a nominal insolation of 1kW/m2 @ 25degC but varies considerably in a normal operating environment. A ~16V battery connected to a 12V nominal PV panel will loose a considerable portion of its potential energy capture due to the panel not making it significantly above the battery potential for a considerable portion of your typical day.
A 16V battery would cause problems for a lot of loads designed for use at 12V (most inverters have an over voltage cut off less than this).
What exactly makes 4x4V lithium ion cells better than say 7x2.3V lead acid?
If I have misread your intention then disregard my comment, but you may want to look at clarifying your position.
« Last Edit: May 29, 2007, 03:04:47 PM by jimovonz »
alancorey
« Reply #2 on: May 29, 2007, 03:54:14 PM »
Li-ion? Like the ones in laptops that only last about a year? No thanks.
  Alan
« Last Edit: May 29, 2007, 03:54:14 PM by alancorey »
AbyssUnderground
« Reply #3 on: May 30, 2007, 11:01:35 AM »
They only last about 1 year for most people because they're not looked after. EG, extreme heat from the laptop itself, overcharging because its on the mains 24/7, not storing at 40% charge etc. Lithiums should last years if well looked after.
« Last Edit: May 30, 2007, 11:01:35 AM by AbyssUnderground »
