Author Topic: Which wire on vertical fan?  (Read 1103 times)
« on: July 31, 2007, 09:10:01 PM »
I'm not too much on trouble shooting electronics,
so I just gutted the whole works so basically I'm
just going to hook it up direct....maybe medium
speed am keeping the fuse and using it.
  Okay.....Now this motor has a black wire,brown,
yellow, blue, white, and red wires....now how do
I use a multimeter to determine which is the common
wire and the wire that I would need for one of the 3 speeds....I'd mainly just probably hook it
up for medium speed.
     Thanks for any help guys need the air out in
my shop while I'm making one of those low voltage tread mill motor fans.
              ( :>) Norm.
« Last Edit: July 31, 2007, 09:10:01 PM by (unknown) »
Re: Which wire on vertical fan?
« Reply #1 on: July 31, 2007, 03:30:17 PM »
Hi Norm
I would think Black/Blue/Red would be the speeds
White is common
Brown/yellow would be part of the start winding i think.
 If all else fails make a turbine out of it.
Have fun.
« Last Edit: July 31, 2007, 03:30:17 PM by vawtman »
« Reply #2 on: July 31, 2007, 06:14:03 PM »
Okay Vawtman, I'll try that tomorrow probably put
it in series with a 20 watt 110 volt bulb for testing huh?  I'll let you knopw how it works out.
      ( :>) Norm.
« Last Edit: July 31, 2007, 06:14:03 PM by Norm »
stephent
« Reply #3 on: July 31, 2007, 07:05:47 PM »
Probably close to a ceiling fan type wiring?
http://www.hurontel.on.ca/~taitg/pages/cfan.html
« Last Edit: July 31, 2007, 07:05:47 PM by stephent »
« Reply #4 on: August 11, 2007, 07:32:12 PM »
Norm,
Your mailbox is full...
« Last Edit: August 11, 2007, 07:32:12 PM by ghurd »
