Author Topic: 2.5 hours today off-grid  (Read 1109 times)
« on: August 07, 2007, 08:22:46 PM »
I got about two-and-a-half hours off-grid today.  I think I can increase that by about another 15 minutes tomorrow assuming similar sunshine, by turning off a power-hungry process.
« Last Edit: August 07, 2007, 08:22:46 PM by (unknown) »
Re: 2.5 hours today off-grid
« Reply #1 on: August 07, 2007, 02:57:50 PM »
Damon;
Sounds like you're on your way!!
What tpye of system do you have? I think in you're previous post it was a laptop.
Is it possible to use the energy star setting to go low power? spin down the HD, blank out the screen OR have you already done that and I missed it on the other posts?
Keep up the posts!!
« Last Edit: August 07, 2007, 02:57:50 PM by Bruce S »
« Reply #2 on: August 07, 2007, 04:29:06 PM »
It's a laptop.  Already applied all the power-saving tech currently available and the lid is down to eliminate backlight power draw.
(For the technically minded it's a HASEE Intel Core Duo 1.73GHz, 2GB RAM, 160GB disc, 4GB SD memory card being used as the boot disc, running Ubuntu (Linux) "Feisty Fawn" with a "Gutsy" NO_HZ tickless kernel, laptop mode to spin down the disc, and cpufreqd to manage CPU clock speed.)
More here: http://www.earth.org.uk/low-power-laptop.html
« Last Edit: August 07, 2007, 04:29:06 PM by DamonHD »
« Reply #3 on: August 07, 2007, 06:26:58 PM »
 From the untechy i may need some of them parts for my vawt.Maybe the gutsy tickless feisty fawn hassie from Ubunto to spin it.
 Have fun and nice work.
« Last Edit: August 07, 2007, 06:26:58 PM by vawtman »
« Reply #4 on: August 08, 2007, 12:37:18 AM »
No, no, a spinning feisty fawn may get very sick!  B^>
« Last Edit: August 08, 2007, 12:37:18 AM by DamonHD »
ZooT
« Reply #5 on: August 08, 2007, 11:20:21 AM »
So did you do the kernel build yourself, or use an "off the shelf" kernel?
« Last Edit: August 08, 2007, 11:20:21 AM by ZooT »
« Reply #6 on: August 08, 2007, 12:41:23 PM »
I have built a kernel myself but in the end I got the prebuilt Gutsy kernel.
When I have a little more time, and 2.6.23 is a little more advanced and/or gets the full set of 'force-HPET' and cpuidle patches in, I may build a new kernel with those.  Not quite sure what kernels I can mix with which 'userland'.  I've been more a Solaris person in the past!
« Last Edit: August 08, 2007, 12:41:23 PM by DamonHD »
