Author Topic: Need quick float fix  (Read 1775 times)
« on: September 27, 2007, 11:53:31 PM »
What kind of stuff can I smear on a brass
carbuerator float so it won't leak?
Would coating it with epoxy work?
Desperate to get it fixed for the neighbor
so I can get back to the swing project before
winter sets in ( the swing powered air-compressor
and battery-charger.)
             Thanks for any help.
          ( :>) Norm
« Last Edit: September 27, 2007, 11:53:31 PM by (unknown) »
Re: Need quick float fix
« Reply #1 on: September 27, 2007, 05:56:12 PM »
Norm;
Not to be a wiseacre but why not solder it?
« Last Edit: September 27, 2007, 05:56:12 PM by TomW »
« Reply #2 on: September 27, 2007, 06:26:45 PM »
Yeah Tom...that ought to work ....thanks !
            ( :>) Norm.
« Last Edit: September 27, 2007, 06:26:45 PM by Norm »
« Reply #3 on: September 28, 2007, 06:48:56 AM »
repaired the float of a single throat holly with solder.
careful of any gasoline residue on the inside.
« Last Edit: September 28, 2007, 06:48:56 AM by electrondady1 »
spinningmagnets
« Reply #4 on: September 28, 2007, 07:12:08 PM »
Sand around the float crack with a fine grade of sand paper (200-400 grit) to improve "grip" and thoroughly clean it (removing oily residue), then coat the leak with "JB Weld" (a type of chemical-resistant epoxy) available cheaply at any automotive store or Wal-Mart.
I don't want to sound like a "hillbilly" but I have fixed a dozen things with this.
« Last Edit: September 28, 2007, 07:12:08 PM by spinningmagnets »
« Reply #5 on: September 28, 2007, 07:23:35 PM »
Not sure JB works with gas
« Last Edit: September 28, 2007, 07:23:35 PM by ghurd »
spinningmagnets
« Reply #6 on: September 28, 2007, 09:39:46 PM »
I agree if you have the ability to solder or braze, that would be the preferred option. JB is a good temporary "road-side" fix-all. Meybe not the best long term repair.
« Last Edit: September 28, 2007, 09:39:46 PM by spinningmagnets »
elvin1949
« Reply #7 on: October 01, 2007, 11:40:54 PM »
 It will. I use it all the time on gas tank's and
carb float's.
Elvin
« Last Edit: October 01, 2007, 11:40:54 PM by elvin1949 »
update on float fix
« Reply #8 on: October 02, 2007, 06:56:31 AM »
 I'm an idiot (and don't argue with me that I'm
not....LOL ).
 I jumped to conclusions, a couple of years back,
when I was working on this engine and took the
carb apart I discovered that at one time it had
got water in the float bowl, frozen and the ice
had dented the bottom of the float. So I thought
just in case it might have caused a leak, I
sprayed it with clear ?enamel,lacquer, poly u ??
whatever, anyhow it hadn't worked. When gas kept
overflowing from the carb...I figured that the
float was leaking again and it couldn't shut the
gas off. So...took it apart and found that coating
had peeled off and was causing the float to stick...
cleaned the carb all up with carb cleaner
shined the float with steel wool couldn't find
anyplace where it could be leaking...put it all
back together ...turned the gas back on...no sign
of overflow from the carb after a few hours...
maybe it was okay? Shut it off, turned
 it back on in the morning kept a close eye on it all day
...started it up couple of times...kicked right
over and run just like they should when correctly
adjusted ! So much for jumping to conclusions.
  Thanks for the help...just knowing you guys
are there ready to help keeps me going every day.
Havin' fun in Conneaut, Ohio
                 ( :>) Norm.
« Last Edit: October 02, 2007, 06:56:31 AM by Norm »
Re: update on float fix
« Reply #9 on: October 02, 2007, 07:48:35 AM »
Norm;;
Haha, and you thought remote telepathic repair was a myth!
The bill will be there in a couple days. It will arrive by postal mail, however.
« Last Edit: October 02, 2007, 07:48:35 AM by TomW »
« Reply #10 on: October 02, 2007, 01:06:50 PM »
Hope it isn't too expensive?
    ( :>) Norm.
« Last Edit: October 02, 2007, 01:06:50 PM by Norm »
