Author Topic: Repurposing Industrial Scrap  (Read 2841 times)
healerenergy
« on: October 05, 2007, 02:02:53 AM »
I recently brought home a massive motor and flywheel and am going to set it up as just a flywheel for my combined energy project. This is just the beginning of a big project.
I am going to start with some of the math.
I am pretty good at some math but would like help making sure I get things right with this project
So far I found some pretty good math on line but have never used this exact kind of math before.  The math I found is this
Physics:
        Stored energy = sum of kinetic energy of individual mass elements that comprise the flywheel
        Kinetic Energy = 1/2*I*w2 , where
        I = moment of inertia (ability of an obeject to resist changes in its rotational velocity)
        w = rotational velocity (rpm)
        I = k*M*R2  (M=mass; R=radius); k = inertial constant (depends on shape)
Inertial constants for different shapes:
        Wheel loaded at rim (bike tire); k = 1
        solid disk of uniform thickness; k = 1/2
        solid sphere; k = 2/5
        spherical shell; k = 2/3
        thin rectangular rod; k = 1/2
I need to do this for both the rotor and the flywheel so I can find out how much horse power I will have to have to get it moving and up to speed.
The flywheel weighs 6920 pounds.
The rotor now weighs 6120 pounds.
The shaft weighs 3580 pounds.
George
« Last Edit: October 05, 2007, 02:02:53 AM by (unknown) »
wdyasq
Re: Repurposing Industrial Scrap
« Reply #1 on: October 04, 2007, 08:58:08 PM »
Yes, your formulas are correct. I would convert the 'pounds' to kilograms or Newtons so you will get your answer in Joules, which are "Watt/seconds". Remember that power is a function of time.
I wish I knew of a good Physics website to get you up to speed. Remember as you calculate this that if the flywheel fractures, all of the energy is quickly absorbed by the surrounding or nearby structure. One does not want to be part of that structure.
« Last Edit: October 04, 2007, 08:58:08 PM by wdyasq »
healerenergy
« Reply #2 on: October 04, 2007, 10:06:00 PM »
The compressor that this motor and flywheel used to belong to ran at 350 rpm and I am considering possibly taking it to 500 rpm but no more than that.  I think your idea of changing from pounds to kilograms is a good thing.  So the
flywheel is 3 138.859 200 4 kilogram
rotor is 2 775.985 304 4 kilogram
shaft is 1 623.860 684 6 kilogram
George
« Last Edit: October 04, 2007, 10:06:00 PM by healerenergy »
healerenergy
« Reply #3 on: October 04, 2007, 11:43:01 PM »
I found this site on one of my google searches.
http://flywheel.esmartbiz.com/basics.htm
George
« Last Edit: October 04, 2007, 11:43:01 PM by healerenergy »
Capt Slog
« Reply #4 on: October 05, 2007, 03:01:52 AM »
This is really good...
http://hyperphysics.phy-astr.gsu.edu/hbase/hph.html
It takes a little navigating at first, but once you're into it, it's very helpful.
« Last Edit: October 05, 2007, 03:01:52 AM by Capt Slog »
BigBreaker
« Reply #5 on: October 05, 2007, 07:01:29 AM »
I think you mean watt x seconds
« Last Edit: October 05, 2007, 07:01:29 AM by BigBreaker »
BigBreaker
« Reply #6 on: October 05, 2007, 07:26:55 AM »
You will find yourself with enormous power potential in that flywheel, but less energy than you would guess.  It would be great for welding, motor starts and other short term high power needs.  As a battery it'll be terrible.  Only the high tech, high RPM flywheels achieve decent energy density.  You also need to contend with frictional losses - the high tech flywheels use air or magnetic bearings.
Think about it this way, 500 RPM is ~8 RPS.  The effective diameter of the flywheel is? 2 meters?  So the circumference is about 6 meters.  8 RPS and one rev = 6 meters, so ~5000 Kg at 50 m/s.  Kinetic energy is .5 x mass x speed^2, so .5 x 5000 x 50 x 50 = 6,250,000 joules or 1.7kWh.  A 12v battery bank of similiar capacity would have 140 Amp hours.
One thing about flywheels... double the RPM, quadruple the energy storage.  That's why the big boys spin their composite wheels at 30k+ RPM.  If you spin that wheel up to 2000 rpm, you'll have 20+ kWhs to work with.  Lock'r down tight!
« Last Edit: October 05, 2007, 07:26:55 AM by BigBreaker »
healerenergy
« Reply #7 on: October 05, 2007, 04:47:11 PM »
I really thank you for your input and I will try to have all the measurements in a day or so, so we can do this right. I haven't measured the diameter of the flywheel yet but I think it is nearer 8 feet than 6 feet.
Rotor ID is 145.5 cm
Rotor OD is 162.5 cm
Rotor height 162.5 cm
George
« Last Edit: October 05, 2007, 04:47:11 PM by healerenergy »
« Reply #8 on: October 05, 2007, 06:13:30 PM »
sence you have such a hugh flywheel this might be a good read--just one out of many on google search...
                http://www.rustyiron.com/engines/flywheel/
« Last Edit: October 05, 2007, 06:13:30 PM by hiker »
healerenergy
« Reply #9 on: October 06, 2007, 05:16:05 PM »
Thanks for the site it is a good piece of information.  My main intent is to even out the energy between my VAWT and generator or alternator.  So I don't think I will be spinning this up to real high speeds.
« Last Edit: October 06, 2007, 05:16:05 PM by healerenergy »
healerenergy
« Reply #10 on: October 08, 2007, 06:17:17 PM »
As promised the flywheel specs follow.
Flywheel ID 212 cm
Flywheel OD 256 cm
Flywheel height 256 cm
George
« Last Edit: October 08, 2007, 06:17:17 PM by healerenergy »
healerenergy
« Reply #11 on: October 08, 2007, 06:39:12 PM »
I thought it was time to show everyone all the pieces of the motor less bearings so here goes.
Stator
Rotor halves
Shaft with counterweights
Flywheel halves
George
« Last Edit: October 08, 2007, 06:39:12 PM by healerenergy »
BigBreaker
« Reply #12 on: October 09, 2007, 01:18:05 PM »
My approximations are still going to be pretty close.  The real variable is the speed you run the flywheel, not the diameter.
« Last Edit: October 09, 2007, 01:18:05 PM by BigBreaker »
